Damping
Damping
Old 9th April 2013, 08:54 PM   #11
kinku is offline kinku  United States
Damping
Thank you oshifis.I guess those recommendations are for woofer inside a vented enclosure.What about a full range speaker inside a vented box?
Old 10th April 2013, 02:36 AM   #12
larryldspkr is offline larryldspkr  Canada
larryldspkr's Avatar
I've been using Bonded Logic cotton house insulation with great success! Add and subtract to taste!
Larry
Old 10th April 2013, 01:59 PM   #13
lcsaszar is offline lcsaszar  Hungary
In this case stuffing does make sense, indeed. You have to find a good compromise between effectively damping wall reflexions and not overstuffing so that the LF response is affected too much. Although not a vented box, I stuffed the compression chamber behind the speaker in my full range horn with glass wool, and the sound became much less "raw".
DampingHide this!Advertise here!
What to use for damping afterglow Full Range 1 5th May 2008 08:01 AM
Help~~damping hitboy_sw Everything Else 4 13th February 2004 02:22 PM
Damping and bracing? jvsb Multi-Way 2 28th October 2003 03:32 PM
Damping Material Jhovis Multi-Way 5 29th September 2003 08:35 AM
silicon damping Nat Eddy Analogue Source 5 6th June 2003 11:43 AM
