2x10 or 1x12" UK Woofer suggestions please.
Old 12th April 2013, 08:41 AM   #21
Studio Au is offline Studio Au  United Kingdom
Beyma looks good, and at can be found for 60.
I might just buy two and build one cabinet to start.
Thanks Barackuda.
Any other suggestions that make the shortlist?
Old 9th June 2013, 08:56 PM   #22
What about the Seas units with a passive radiator
D1004-04 L26RO4Y
Old 11th June 2013, 02:13 AM   #23
mayhem13 is offline mayhem13  United States
Older thread....not sure if you decided but I'd add that I'd go the dual 10" route to avoid floor bounce which would be forced if using a single bass driver given how close it needs to be to the Fullrange.
There's not a lot of pro 10's that dig deep.....they're mostly midbass units. That being said, there's plenty of hifi 10's that will dig deep and as a pair will provide some added efficiency. Scanspeak Discovery 26w in a series pair would be my choice in 2.75cuft ported.
Old 14th June 2013, 09:28 PM   #24
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Default +1 barackuda
hadnt seen that Beyma before. Interesting. With the higher Q could be best with a PR -in my limited experience Q comes out usually a bit higher than published data.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 17th June 2013, 02:55 PM   #25
I have my new soon to be collected Wild Burro Betsy's to play with soon....
but still unsure of which drivers to get for my Fast 'bass cabinet'.
This is for low re-informent, and hopefully the alpair will do from 100Hz up, should I discount Subwoofers, like the L26RO4Y?
Old 17th June 2013, 03:02 PM   #26
oooh, those Beyma's are used in a few open baffles...
Old 18th June 2013, 09:50 AM   #27
So Beyma 10BR60, 2 per side sound like a good starting point?
Old 20th June 2013, 02:19 PM   #28
Ok decided, I want the Beyma 10BR60. I have a Rotel RMB 1048 with 8x40w of power amp flying to me soon.
Now I just need a great cabinet design...These will be actively crossed, and using the MiniDSP will have control so can adjust on the fly.
I want the cabinet to be curved, with a small width baffle as possible. That is all I require.
Any ideas for ported designs, or sealed, push/pull, push/push etc...?
Old 3rd December 2013, 08:52 PM   #29
Well, still haven't purchased.
Been looking at having OB woofers, especially to mate with my Betsy's that are sat around.
Any reason not to try a Eminence Alpha 15a each side, running OB as a FAST, helper woofer?
These are still to be mated to Alpair 7.3 for 100Hz or so up. And to be tried out with the Betsy.
2x10 or 1x12" UK Woofer suggestions please.Hide this!Advertise here!
Suggestions for 4" Woofer for two way diypass Multi-Way 15 8th March 2013 08:53 AM
8" woofer suggestions MunkeyQ Multi-Way 36 10th May 2011 10:27 PM
Need advise: 1x12" plus 2x15" organ speaker platplaas Multi-Way 5 28th October 2010 02:52 AM
Woofer suggestions (UK) FullThrottleRic Multi-Way 7 17th August 2006 02:43 PM
2x10" woofers amoeba86 Multi-Way 3 9th May 2003 07:04 AM
