Shared box calculaton
Old 27th March 2013, 11:36 AM   #11
costis_n is offline costis_n  Greece
Hmmm looking at thomann, I saw the FRS-8
Visaton FRS 8M - Thomann Greek Cyberstore
almost the same bass extension, and only needs a 6 liters box, or 12 if i share the box (quick calculation). What do you guys think?
Old 31st March 2013, 09:20 AM   #12
Hmm seems i messed up the volume calculation for these drivers,
http://www.visaton.de/en/chassis_zub...nd/frs8_8.html
Should be around 2x2.3 , what do you guys think?
Old 31st March 2013, 02:35 PM   #13
SpirosZ is offline SpirosZ  Greece
With sensitivity at 82db I wouldn't even bother.
These are not cheap but I believe they will rock Faital Pro 4FE32 4 30 Watts 8ohm loudspeaker : Lean Business, Oustanding Audio, Bass Guitar Speakers, Celestion Guitar Speakers, Guitar Amps, Tayden Guitar Speakers, Pro PA Speakers, Celstion spares, Celstion Vintage 30 and more!
2X5lt tuned at80Hz 91db/w
Old 31st March 2013, 04:51 PM   #14
Spiros you are right about the sensitivity. And yes the Faital look very good, but maybe a little over budget.
I asked the local Peerless importer about TC9FD/TG9FD, I ll know it a few days.
Thanks!
Old 22nd April 2013, 07:17 AM   #15
The importer has not any stock on the Peerless, waiting for an answer for these
FaitalPRO | LF Loudspeakers | 4FE32
91db and a nice response!
Old 30th April 2013, 07:08 AM   #16
Something like that. Electronics go to the back compartment, solar cell on top
Port depth is not there, just the opening. For reference, the drivers are 4''
Old 30th April 2013, 02:32 PM   #17
rjsaenz is offline rjsaenz  United States
SpirosZ
Thanks for your suggestion. I am also looking for a lightweight 8ohm loudspeaker for a speaker backpack. I took a look at your suggestion of the faital pro 4fe32. I almost passed it bye because the link had the specs incorrect on the weight. It said 2.8kg but it is actually 270g. I found another spec sheet for anyone interested it.
http://www.faitalpro.com/products/files/4FE32/8/4FE32_datasheet_8.pdf
I think this might work for my application. Good suggestion.
Does anyone have any experience with this driver ? How does the sound compare with the fostex fe103en, fe126en ?
Thanks Robert
Old 30th April 2013, 04:37 PM   #18
I Just ordered these
FaitalPRO | LF Loudspeakers | 4FE35
Any comments on the enclosure?
Old 30th April 2013, 06:29 PM   #19
Costis, how much were they? Where did you ordered them from?
Robert that link doesn't work.
Old 30th April 2013, 07:46 PM   #20
Sorry try this link
faital pro 4fe32
faital pro 4fe35
Robert
Shared box calculatonHide this!Advertise here!
Shared Cathodes 300b ClefChef Tubes / Valves 10 9th March 2016 11:30 AM
VL85 finecheapamp unfinished schematic shared ontoaba Solid State 0 10th June 2010 09:57 AM
Connectors for shared power transformer 454Casull Power Supplies 0 20th April 2009 11:23 PM
SE With shared Rk in output mashaffer Tubes / Valves 18 13th October 2008 10:10 PM
shared parts between channels metebalci Tubes / Valves 18 21st May 2004 04:16 PM
