I built FH3's, now recommend my next "classic rock" full-ranger - Page 6 - diyAudio
Old 29th March 2013, 05:20 PM   #51
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by Godzilla View Post
I like Mike B1's suggestions. I also like having more than one system tailored to different rooms. If he swapped his speakers in his rooms the sound wouldn't be as good. Fun thread with lots of good ideas.
Who wouldn't want a 600 watt coaxial setup in their garage rafters? That would seriously cause some neighborhood disturbances if turned on full power.
Old 30th March 2013, 03:28 AM   #52
Mike B1 is offline Mike B1  United States
Mike B1's Avatar
It can get loud - I think I SPL'ed about 115 dB.
It's been through a lot of iterations. It started out with a passive XO and driven with a car amp. Then a Berhinger A500. Then 2 A500's and an active XO and the car amp drove the tweets. Then the Seliniums instead of the (forgot what it was) comp drivers.
The best addition was that Bellari "Sonic Exciter". It has a couple of 12AX7's in it and does magic to the sound. Before the Bellari I would crank it till the clip lights blinked, but soon down as it was a little harsh. With the exciter, I can do the same thing and it sounds so good I could just leave it on till the cops came or the speakers melted.
Fun stuff. Kinda amazing too. It's really loud in the garage but I can walk out to the street or the property line and yeah, I can still hear it, but the sound of a car going by will cover it up. Dunno. It's not as loud outside as I expected it to be. Even with the big door open. Maybe cause they are pointed down at a concrete floor and the sound is bouncing up?
Old 30th March 2013, 04:37 AM   #53
xrk971's Avatar
It's actually 2x500 watts or a kilowatt! Wow. Depends on how far away the property line is. Sound falls of as 1/r^2 so probably is fine 100 ft away. I always wondered why anyone needs a 500 watt amp for a home system.... you know, there is a neat thread in the Class D forum about a real simple and cheap 1200 watt amp using nothing more than two power mosfets driven by an IR2110. The power supply is just wall plug with no xformer but a rectifier and caps to get 120 volts to feed the mosfets. People who built it say it sounds great. Now you can have 2400 watts for your garage!
ucd 25 watts to 1200 watts using 2 mosfets
Old 30th March 2013, 05:20 AM   #54
sippy is offline sippy  United Kingdom
Originally Posted by chris661 View Post
Think I'd go for the Eminence 12"er.
Search for the EmKen thread.
Chris
Utterly scary speaker
They can sound a tiny bit congested at high(er/ish) levels with rock type music, but then I've never heard a 'speaker system that doesn't.
Drivers need but a few very simple mods to improve them, they are also fairly cheap and robust..... but need a HEAP of in cabinet running in.
Your amp will be totally overkill as sensitivity is right up there - 97db/w
One could always use EmKen as a base for a FAST type system (sorta what I have planned).
Ladies & Gentlemen - The Emken
Old 30th March 2013, 09:50 AM   #55
tlarwa is offline tlarwa  United States
Can someone point me to the plan set for the Emken? Or does one even exist?
Old 30th March 2013, 02:04 PM   #56
Send a pm to Planet10 (Dave) to find out what the fee will be, JKRO's thread was of the beta buildings.....
Kenwood KD-500 "The Rock" DD Turntable $150 limono Swap Meet 5 2nd November 2012 05:09 AM
Wooden 3" Full Ranger activexp Full Range 10 5th August 2011 11:51 AM
Bruce Horns with classic 8" Jensen full range drivers brsanko Swap Meet 1 10th June 2010 03:28 PM
Kofi Annan in: "The Full-Ranger and Swan-to" Kofi Annan Full Range 62 16th April 2009 09:34 PM
Full Ranger in a "large" room? musgofasa Full Range 36 27th December 2007 12:20 AM
Copyright 1999-2017 diyAudio
