APEX TQWT
APEX TQWT
Old 22nd March 2013, 01:37 AM   #1
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default APEX TQWT
TQWT box idea for 6 inch driver.
Old 22nd March 2013, 09:43 AM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
A nice looking box, but which 6in driver in particular? Since like any other vented alignment the box tuning & volume of a QW pipe need to be appropriate for / designed for the intended drive unit's requirements, it would be useful to know which you had in mind.
Old 22nd March 2013, 11:13 AM   #3
apexaudio's Avatar
Many 6in or 5in drivers can be used and tuning response with damping material.
This box is idea for test TQWT and I will share project with crossover.
Old 22nd March 2013, 11:49 AM   #4
Scottmoose's Avatar
Very possibly, but in what general region of Q and Vas for the alignment you anticipate / intend?
Old 22nd March 2013, 12:49 PM   #5
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Indeed! A TQWP as shown would want a fairly low Q driver. A high Q driver would need an entirely different folding to place the driver nearer to the closed end. Finally, the overall volume of the pipe would depend on the Vas of the driver, which is all over the place in available 5-6" drivers.
Bob
Old 22nd March 2013, 01:06 PM   #6
apexaudio's Avatar
I intended to use VISATON AL130
http://www.visaton.com/pdfexport/de/...f/al130_8.html
but look at this box like TQWT idea.
Old 22nd March 2013, 02:04 PM   #7
Bob Brines's Avatar
AH! OK.
My first impression looking at the T/S parameters is that a Qts of 0.38 may be a little high for a TQWP, but probably doable. The Vas of 13l, though is going to produce quite a challenge making the passages small enough.
Good luck!
Bob
Old 22nd March 2013, 02:15 PM   #8
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
APEX TQWT
I think that the AL130 driver would work well in MLTL.
Old 22nd March 2013, 02:18 PM   #9
apexaudio's Avatar
Originally Posted by Bob Brines View Post
AH! OK.
Good luck!
Bob
Thanks, AL130 is from old T line box and I like this box size for small room.
Old 3rd April 2013, 10:11 PM   #10
apexaudio's Avatar
T Line for 8 inch driver, size 36x22x80cm
APEX TQWTHide this!Advertise here!
Apex HV23 Shelah Solid State 5 23rd October 2012 07:31 PM
Apex Junior amp? cyberspyder Subwoofers 30 26th March 2010 02:50 AM
Apex PA04 hoibit Chip Amps 0 22nd May 2008 03:10 AM
apex opamps tubedude63 Chip Amps 3 19th February 2004 05:09 AM
