Looking for 2 full range speaker recommendations
Old 18th March 2013, 04:07 AM   #1
ChrisRiggle is offline ChrisRiggle  United States
Default Looking for 2 Shielded full range speaker recommendations
Hi all,
I started to do a desktop build a while back but had to postpone due to life interrupting. Anyhow I'm back and ready to do a desktop build similar to the link below. I really need a 4 inch shielded full range speaker recommendation for the amps below. Price wise for the Lp-2020a I'd like the speakers to be around 20 to 30. The Qinpu - A-6000 MKI is another amp I'm looking at down the road for and upgrade. I'd also appreciate a 4" speaker recommendation for it with a price range around $80.00 each.
http://www.wellroundedsound.com/438020/corgi/
LP-2020A+
Amazon.com: LP-2020A+ Lepai Tripath Class-T Hi-Fi Audio Mini Amplifier with Power Supply: Electronics
Qinpu - A-6000 MKI
Amazon.com: Qinpu - A-6000 MKII - Integrated /Headphone Amplifier: Electronics
Chris
Old 18th March 2013, 04:53 AM   #2
zman01 is online now zman01  Bangladesh
You can take a look at the Mark Audio Alpair 7.3, CHR-70.3, and the Tang Band W4-1320SIF.
Lot of folks have done builds on the forum with these drivers and there should be plenty of review/listening impressions based on their expereinces.
Old 18th March 2013, 05:21 AM   #3
Thanks for your reply. Those speakers have came up on my searches and I have the Tang Band saved as one of my favorites. Do they make shielded versions of these speakers? They will be used on my pc desk and I always have items that aren't magnet friendly on my desktop charging or docking. You know, cell phones, tablets, HDD etc.
Old 18th March 2013, 06:29 AM   #4
The MA Alp 7.3 is magentically shielded IIRC.
Edit: Noticed that you had mentioned "shielded" in the subject line of the first post.
Old 21st March 2013, 10:58 AM   #5
How do you feel about the Tang Bands W4-1337D? Shielded, full-range, what's not to love? From what I'm reading the MA Alp 7.3 would need a larger inclosure than what I'm going to be building.
Power Handling (RMS) 25 Watts Power Handling (max) 50 Watts Impedance 8 ohms Frequency Response 70 to 20,000 Hz Sensitivity 87 dB 1W/1m Voice Coil Diameter 1"
THIELE-SMALL PARAMETERS Resonant Frequency (Fs) 70 Hz DC Resistance (Re) 6.8 ohms Voice Coil Inductance (Le) 0.02 mH Mechanical Q (Qms) 1.51 Electromagnetic Q (Qes) 0.49 Total Q (Qts) 0.37 Compliance Equivalent Volume (Vas) 0.17 ft.³ Mechanical Compliance of Suspension (Cms) 1.05 mm/N BL Product (BL) 5.37 Tm Diaphragm Mass Inc. Airload (Mms) 4.61g Maximum Linear Excursion (Xmax) 3 mm Surface Area of Cone (Sd) 57 cm²
MATERIALS OF CONSTRUCTION Cone Material Titanium Surround Material Santoprene® Basket / Frame Material Cast Aluminum Magnet Material Neodymium
Old 22nd March 2013, 03:42 AM   #6
ChrisRiggle,
I haven't heard the abovementioned TB model. I've listened to the Alp 7.3 and really liked it. You can get some enclosure ideas here:
Frugal-phile | Box Library / Mark Audio
The P10 Mini Onkens are reasonably sized bookshelf speakers.
Old 22nd March 2013, 05:13 AM   #7
jerrymchill is offline jerrymchill  United States
Chris, both amps are not the best choice, the Lepai is fun for a short while then you realize how distorted it sounds - it is a cheap build - nothing for serious listening - perhaps for backyard... The very best champ on the block is the Dayton DTA 100a for mere $80.00 or so. U simply cannot do better than that. They have some quality issues but if get lucky it's the best $80.00 you will ever spend.
4" drivers - TB is a good choice as the sound is natural out of the box, other drivers will take lot of time to tune. But if this is for a desktop I would consider 3" TB drivers as there is simply no contest in resolution and fidelity - the 4" drivers sound already congested if not implemented properly.
Old 22nd March 2013, 05:46 AM   #8
Mike B1 is offline Mike B1  United States
Mike B1's Avatar
I built these computer speaks with Tang Band W4-1320SJ. 4 inch PVC T and end cap. About 3.5 liters tuned to 80 Hz.
It's a neo motor, but it is enclosed with steel. Don't know how shielded it is, but it sounds real good. Near field, about 18 inches from my head.
Old 22nd March 2013, 08:04 AM   #9
For now I've ordered 3" Tang Band drivers and a Lepai amp. I really wanted to go with Mark Audio but I wasn't able to find a speaker that would work for my application, shielded 3" to 4" that will be great for a small enclosure.
Jerry, Thank you for your post. It lead me to about 3 hours of reading. I really like the look of the DTA100a and the reviews are great. As you point out, I'm a little worried about the reliability. However after reading bout it and class T amps, it lead me to the topping TP30 amp. It's only 15w but has an on-board sound card. For my application, on my computer desktop, I think it'll fit my application best.
Old 23rd March 2013, 01:59 AM   #10
Chris, the Topping TP 30 is a good amp - sounds refined with the 3" TB - that will be a great set up. The USB DAC on it is couple of years old but sounds fine.
Definitive upgrade over anything on the plastic black box market. Cheers!
Looking for 2 full range speaker recommendationsHide this!Advertise here!
Full Range Speaker recommendations for portable audio quincylala Full Range 6 30th March 2013 03:39 PM
Newbie alert: Recommendations for full range desktop drivers? sindriss Full Range 3 16th February 2012 12:01 AM
Full range active speaker zebra100 Full Range 10 24th August 2009 12:28 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
Technics Full Range Speaker HKC Full Range 0 5th June 2006 02:33 PM
