Accidental MLTL Technique
Old 28th August 2013, 08:20 PM   #221
GM is offline GM  United States
GM's Avatar
For a high Qt one it could, but need specs to check...........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th August 2013, 08:53 PM   #222
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
GM
Here are the parameters
SD=532 cm2
fs=44.4 Hz - measured, factory is 47 Hz
Mms=34 g
Qms=6.00 - measured, factory is 6.69
Qes=0.635 - measured, factory is 0.51
Re=5.64 ohm - measured, factory is 5.57 ohm
Le=0.982 mH - measured, factory is 1.01 mH
Vas=161 liters
xmax = 3.5 mm
I should add that the Sd, mms, xmax, and Vas were taken from the manufacturer specs and I expect the Vas may not be accurate if the Qms and Qes varied from the spec.
I did not do the measurements - provided with the drivers.
Old 28th August 2013, 11:25 PM   #223
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
SD=532 cm2
Mms=34 g
Vas=161 liters
xmax = 3.5 mm
Hi xrk971,
Here is two attempts using your Driver targeting flat FR:
b
Old 29th August 2013, 03:34 AM   #224
Got Foam?
xrk971's Avatar
Bjorno,
Thanks for the simulation. If I am reading your Hornresp input page correctly, this says that you suggest a 700 square inch CSA (or 22.5 in wide x 31 in deep) x 43 in long TL with a 9.3 in dia hole in 18 mm (3/4 in) thick plywood as the vent? This makes for a shorter box but the CSA is kind of big and the location of the driver is only 21 in off the floor - not close enough to ear level. But the volume is the same as I have and it does show that you are getting a flat bass response down to 28 or 29 Hz. I am not sure how to interpret your second sim - the one shown in the Mathcad sheet.
X
Btw, here is the freq response (again), impedance, cone excursion, and impulse response for my 60 in MLTL.
Old 29th August 2013, 05:21 AM   #225
GM's Avatar
OK, WinISD calcs 0.574 Qts, 151.73 L Vas, 9.17854 BL. Adding a ohm for speaker wiring and Qts = 0.62, making for a manly sized ~626.6 L/22.13 ft^3, 29.5 Hz Fb T/S max flat alignment. For sure, bigger than my speakers, fridge by ~2 ft^3 net.
GM
Old 29th August 2013, 11:25 AM   #226
Got Foam?
xrk971's Avatar
Thank you, GM. Confirms my suspicion of a need to use a refrigerator sized box.
But hey, the deep bass is really going to be good with a 95 to 97 dB efficiency.
One other question. With the Qts being higher, is this a good candidate for an open baffle? A CD horn in a 12 in coax in an open baffle is something I don't recall ever coming across before.
Old 30th August 2013, 03:20 AM   #227
Got Foam?
xrk971's Avatar
Sorry guys, I just realized I had a typo on the params I provided earlier. Also there are two drivers and they differ slightly so I averaged them out. How do you get WinISD to provide the BL and Vas based on the parameters I provided?
Here are the new averaged T/S params.
Thanks,
X
SD=532.4cm2
fs=46.1Hz
Mms=34g
Qms=5.258
Qes=0.695
Re=5.55ohm
Le=0.979mH
Old 30th August 2013, 04:32 AM   #228
GM's Avatar
Note the 'auto calculate' box is checked and the colors of the input values shows what's inputted Vs calculated.
GM
File Type: gif Eminence Beta 12CX measured [early, higher Qt].gif (14.2 KB, 108 views)
Old 30th August 2013, 05:11 AM   #229
Got Foam?
xrk971's Avatar
I did not realize I had such a limited version 0.44. I just downloaded the 'Pro' version and it has these nice features. What an upgrade!
Old 30th August 2013, 05:15 AM   #230
GM's Avatar
A lot more accurate overall too.
GM
Accidental MLTL TechniqueHide this!Advertise here!
Tell us about your accidental discoveries sprinter Music 32 21st October 2013 06:22 AM
Accidental Death of a DoZ... aspringv Solid State 13 22nd July 2012 09:38 AM
Accidental DIY Audio Waterdog Introductions 9 23rd January 2012 06:31 PM
RB250 Rewiring - accidental mess up? InfiniteGain Analogue Source 5 30th January 2009 10:11 PM
