Alpair 10.2 "Castle" ?
Old 14th March 2013, 04:21 PM   #41
cogitech is offline cogitech  Canada
cogitech's Avatar
Originally Posted by Scottmoose View Post
I don't because a/ I would hope & am trying to encourage people to experiment for themselves, and b/ both of the blanket statements you make above are incorrect. In a specific set of circumstances, one or both may be, as you have discovered. In others, it is not. Default is a uniform stuffing density throughout the enclosure, which will not automatically result in 'sub-optimal bass performance' and in many cases provide superior results.
OK, Scott. You know better than I do. That's a given.
I was simply relating my experience and my desire to have had more of a guideline.
It would be beating a dead horse to ask, but I am truly curious how many people are running fully stuffed Pensil 10.2 cabinets and getting balanced bass response. 3 people already have expressed surprise that I was running them fully stuffed, as if that was an obvious blunder.
Old 14th March 2013, 04:30 PM   #42
cogitech's Avatar
Regarding A) above (and getting back to the thread topic) would you also encourage me to experiment by cutting a hole in the top of one of the cabinets, installing the second Alpair 10.2 in there, and then playing with different port lengths in an effort to possibly discover another "Accidental" design? A "SuperCastle", perhaps?
Old 14th March 2013, 04:31 PM   #43
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Re the damping, I've given all the guidelines I wish to for these particular boxes. Adjustability was part of the design goal, the details are up to the end user. Some people like fooling with wires for e.g.: playing with damping to suit specific room / system / preferences in these boxes will make a hell of a lot more difference than most wires ever will.
God knows re the latter. I certainly don't, since they're intended to be flexible to allow people to optimise them for individual situations / requirements. As SWAG, I'd anticipate that probably < 50% of the pensil enclosures built (not just the 10.2 boxes) use the default values, what they end up with depending on what people find works best in their particular circumstances.
Old 14th March 2013, 04:35 PM   #44
Scottmoose's Avatar
I was referring specifically to the damping, but if you want to try it, I'm not going to try to stop you. You might be surprised at the results.
Old 14th March 2013, 04:54 PM   #45
fastbike1 is offline fastbike1  United States
I think a cursory review of MLTL designs would show that they are rarely / never fully stuffed.
I was so much older then, I'm younger than that now.
Old 14th March 2013, 05:01 PM   #46
cogitech's Avatar
I agree.
However, I am pretty sure Scott does not refer to this as a MLTL.
Also, he just stated that the default stuffing scheme is in fact "fully stuffed" as per the design plans.
Old 14th March 2013, 05:13 PM   #47
Scottmoose's Avatar
It is indeed an MLTL, but the pensils are a rather specific variation / alignment thereof. Well, truth to tell, the 10.2 box uses a slightly different one, since I wanted to hold height constant across the range, but the same default of being stuffed throughout (well, down to the top of the vent at any rate) applies, with the caveat that it's expected that people will play with the damping to suit themselves (think of it as manly art & craft )
Old 14th March 2013, 06:08 PM   #48
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
My comment was based on the amount I have in my 12p Super Pencils, ~280 grams per box. They are partially lined thou.
jeff
Old 14th March 2013, 06:48 PM   #49
chrisb is offline chrisb
As I usually let Dave parse the amount of fill for my builds, I often don't read some of the fine print on the plan sets - is it just me or those the following from page 10 of the Pensil plan set not make sense?
"1) Stuff with .75lbs /ft^3 (1.59 lbs = .72g) " shouldn't that read Kg or 720 grams?
Jeff's 280g is a little over 1/2 pound, perhaps light if as he says the box was not partially lined ( 1/2" Ultra Touch felted denim, IIRC)
like my mind, this space intentionally blank
Old 14th March 2013, 07:20 PM   #50
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Alpair 10.2 &quot;Castle&quot; ?
It should read kg
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Alpair 10.2 &quot;Castle&quot; ?Hide this!Advertise here!
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
kinda ot... 10" x 10" x 10" aluminum block/bar, does such thing exist? Mickey Pass Labs 9 15th November 2011 08:22 PM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
