Completed Frugel-Horn 3's finished in walnut
Old 4th March 2013, 08:50 AM   #11
doubtingthomas is offline doubtingthomas  United Kingdom
Very classy,one of the best looking builds posted. You probably know this already but walnut, wich I've used quite a bit over the years, changes colour significantly over time especially when exposed to sunlight. It gradually lightens and ends up the colour of straw as opposed to that rich sable brown it starts off as, so unless that's the way you want to head, keep them in the shade.
Old 4th March 2013, 08:51 AM   #12
The roundover is a piece of solid right? Nice detail.
Old 4th March 2013, 09:10 AM   #13
jamikl is offline jamikl  Australia
Beautiful veneer and finish plund. I always think that walnut just looks so classy!
jamikl
Old 4th March 2013, 12:42 PM   #14
gychang is offline gychang  United States
throw out the speaker grills... looking good. what kind of finish on the veneer?
Good sound from Davis, CA
Old 4th March 2013, 01:01 PM   #15
plund is offline plund  United States
I appreciate the compliments on the finish guys! Thank you Planet 10 Dave, Chris, Scottmooose, (and others?) for designing the FH3! I have no idea how to design speakers. I have built speakers where the primary goals were to be inexpensive and quickly-built. Those quickly-built speakers now reside in my garage. These days I try to apply the tips and tricks that some of you great builders share to make speakers look as good as they sound...my trusty Rockwell/Beaver table-saw and I are still working on this.
Doubtingthomas, yes, the roundover is a strip of walnut I cut and laminated-on. I initially tried to roll the veneer over the rounded baltic birch panel in the vacuum bag, but I didn't even come close to getting that to work. The strip of walnut was plan B.
Pete
Old 4th March 2013, 03:51 PM   #16
chrisb is offline chrisb
Pete
even the most flexible paper backed veneer (which wasn't the case here) would be a challenge to wrap around that small radius with conventional methods
and if you didn't tell us about "B", we'd have assumed it was your original plan
very tasty work - and, yes, the 7s have something magical going on from around 3K & up
like my mind, this space intentionally blank
Old 4th March 2013, 08:41 PM   #17
Sfwg is offline Sfwg  United States
Originally Posted by Scottmoose View Post
Blimey. Stunning work.
Stunning was the word that came to my mind as well.
Old 5th March 2013, 12:28 AM   #18
Gychang,
The finish is: Filled the open grain with the sanding/slurry method. followed by a touch of red, yellow, and brown dye. followed by about 10 coats of polymerized Tung oil. After the tung oil, I was liking the finish except I was wanting more gloss so I added three coats of Formbys (wipe-on varnish).
Also, I agree they look better without grills but with two toddler grandsons, prudence calls for grills. Dented Alpair 7's are less attractive than grills.
Completed Frugel-Horn 3's finished in walnutHide this!Advertise here!
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
Completed GR-Research Paradox-3's Hewie Multi-Way 22 2nd October 2013 02:32 AM
