Old 24th February 2013, 11:45 AM   #1
Bill poster's Avatar
Default back loaded horns, which is best, front or rear exit?
I'm sure to open a can of worms with this.
I'm guessing that rear exits are generally in compact designs to help boost the lower frequencies- there is one horn builder in america who states that back horns should never exit at the front, I think it was something to do with the mid frequencies.
Any for and against arguments wd be interesting to read.
Old 24th February 2013, 12:11 PM   #2
Scottmoose's Avatar
No can of worms to open. You seem to be implying in your question that the same horn would be employed irrespective of terminus location; this would seldom be the case in a competent design since the location of the terminus should be integral from the inception, not considered at some later stage as an independent factor. All design types have their own compromises so there is no universal 'best' type -you pick what will best suit your design objectives.
Old 24th February 2013, 12:43 PM   #3
What I've noticed is a recent shift from front to rear exit, even with fairly large commercial designs; so I'm curious as to if there is a growing consensus that rear exit is best, for whatever reason.
Old 24th February 2013, 02:05 PM   #4
Scottmoose's Avatar
Not AFAIK. To an extent, this depends on who is out there at any given moment. There are actually quite a few small companies producing back-horn speakers, but many are only around for brief periods, usually due to a lack of exposure, high overheads and limited sales. What goes around comes around though -give it a few months and you'll probably find a bunch of new start-ups selling designs with forward firing termini.
As I say, it's all about picking the compromises that best meet your design goals. A back-horn with a rear terminus for example is usually designed for boundary loading, i.e. its expansion is set up for use in 1/4 or 1/8 radiation space. The room boundaries are part of the horn's expansion, effectively resulting in a larger horn which is impedance matched to a lower frequency than is likely in, say, a similar sized cabinet with a forward-firing termini (under most conditions). This is all very well & good, but it has its drawbacks too, notably greater reliance on the room acoustics. The in-room power-responses are thus generally very different, underlining the fact that there are no panaceas in audio. What works well in one situation may not in others. Personal taste, both acoustic and aesthetic also come into this.
Old 24th February 2013, 02:24 PM   #5
guangui is offline guangui  Puerto Rico
I agree that room boundaries and speaker possible location in the room has to do with designing a front or back loaded horn. In my case, because of land being a premium, my listening rooms are usually smaller than most of the homes you find in larger countries (ie. Canada, USA, UK countryside, etc.). So, I tend to go with front ported, sealed, and front loaded horn speakers. But, I have found out that some rear ported/horn speakers give a great sound when close to a wall. Though not a horn, an example is the original PSB Alpha SE, though rear ported it was designed by Paul Barton to be placed close to a wall. So, there is no rule of thumb, maybe except for large ports/horns, a matter of trial and error to see what works and what doesn't.
Old 24th February 2013, 03:21 PM   #6
tinitus is offline tinitus  Europe
Originally Posted by Scottmoose View Post
The room boundaries are part of the horn's expansion.........
different corner loading.....I had completely forgot about it
maybe not very effective, but probably have some effect
Old 24th February 2013, 03:37 PM   #7
I personally think a rear horn has less impact from time delay compared to a front firing horn. Perhaps due to spewing less rubbish out into the mid ranges? They certainly sound different to my ears, with the exact same horn paths, and not just in depth or sound volume.
Old 24th February 2013, 08:48 PM   #8
Is it just an accepted, or down to bad design or maybe the length of line being too short? The Voxativ Ampeggios garner good reviews and no mention of this. Wd some kind of internal lining or stuffing help (obviously not so much as to defeat the purpose of a horn).
Old 24th February 2013, 09:06 PM   #9
Scottmoose's Avatar
No it's not accepted as inevitable, yes it's mostly down to poor design, and yes, damping materials can be and regularly are used to attenuate unwanted higher frequencies.
Old 24th February 2013, 10:59 PM   #10
Godzilla's Avatar
Top.
My 103E Rear loaded horns shporsche Full Range 17 15th July 2009 11:16 PM
Front & rear end DUAL Back Loaded Horn + Bass Reflex Hybrid Enclosure nickthevoice Multi-Way 13 19th May 2009 03:09 PM
Rear-loaded horns: disadvantages? Taterworks Full Range 4 3rd October 2007 05:22 PM
Front loaded and back loaded horn DrWoofer.com Subwoofers 0 3rd August 2007 06:55 PM
Need info on designing front/rear loaded bass horns jSisco Multi-Way 7 4th June 2003 12:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
