Screws in Cabinets: Yay or Nay?
Old 18th February 2013, 05:47 PM   #21
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
I' ve used both PVA and PL premium. I don't generally have problems with gaps, so that is not am issue. PVA has an open time of ~10 minutes and set time of less than 1hr. PL has an open time of nearly an hour and a set time of close to 24 hr. So, you wind up working differently. With the PL, I can glue up five sides of a box at once, particularly since it doesn't require a lot of clamp pressure. With PVA, I can only do top, bottom and two sides in the first pass. The third side goes on after he initial assembly sets.
Of course, everyone has their own technique.
Bob
Old 18th February 2013, 06:15 PM   #22
gassit is offline gassit  Australia
Hello Scott and others.
The brace is in contact with the wall about 85% of its length; I was just a little concerned about the remaining 15%.
I'll do as you all suggested, which should eliminate the problem.
Thank again.
Old 18th February 2013, 06:45 PM   #23
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
This is why I converted to using cleats and blinds nails. I hate waiting for things to set up.
planet10 needs your help:
Let's help Ruth and Dave
Screws in Cabinets: Yay or Nay?Hide this!Advertise here!
Bracing overkill yay or nay ? DIFORCE Multi-Way 301 28th February 2013 08:53 PM
Mounting heatsinks upwards,, yay or nay? OllBoll Solid State 5 30th November 2010 11:45 PM
Goldstar OS-8100 100Mhz oscilloscope: YAY or NAY? jarthel Parts 0 27th April 2007 07:28 AM
Copper/Aluminum heatsink - yay or nay? thylantyr Solid State 36 1st July 2004 11:11 PM
Cathode Follower? Yay or nay? SHiFTY Tubes / Valves 25 16th March 2004 06:38 AM
