#41 |
Guangui,
This looks like a Weems horn design - they can be very good but this is the smallest I have seen it - did you use a calculator online to design dimensions? It should sound nice. I think damping here will be polyfill stuffing in the triangle closed end and felt if you have it in the top area to line surfaces directly behind driver and top wall and 4 inches or so of top of back wall to reduce reflected sound. Use polyfill stuffing to taste after the driver little by little probably no more than 2 inches past the driver towards open end as it will really attenuate bass from such a small driver. I don't think you need anything in the main chamber before the terminus. |
#42 | |
#43 |
The sound will be very different than a uFonken. I would imagine much more bass efficiency and extension. The measurement stuff is easy, buy a Panasonic wm61a capsule from Digikey for $2 ea, get several, wire them to a 3.5 mm jack and cable from an old cheap pair of headphones (follow guides online do search for wm61a and measurement) plug into your mic jack and you have a flat mic from 20 to 20 khz. Download the holmimpulse software. There is a thread on it and how to use, it even has a calibration curve for this mic.
#44 |
As I think was mentioned before what you have drawn is a "Weem's Pipe", which is a variation of the "Voigt" pipe. My personal experience with both is that the driver is on the wrong side of the "Weem's Pipe". If you do the modeling, you will see that the driver needs to be farther down, toward to vent. That puts the vent on the back of the cabinet, which may or may not be a good idea depending on room placement.
Bob |
#45 | |
:![]() FH3-inspired Foam Core Mini Build I love the sound from mine. The W3-881si can probably work here too. |
#46 |
Great info from all! Will check on the port, I prefer front as they will be very close to a wall. Though the wall might help with bass response.
#47 |
That's one of the advantages of rear-firing ports or horns, the wall boundary enhances the bass even more. If you flip the port to the back and have room for a horn, the bass enhancement is even better. I think you can use the design I have in the above thread for the Tang Band, the drivers are close enough in size, but it wouldn't hurt to order some TC9FD's on the next order from PE or Madisound
, it is only $2 more than W3-881wsi . |
#48 | |
-- Good sound from Phoenix, AZ
#49 | |
#50 | |
| "nanoTower" - Tang Band W3-881SI | cogitech | Full Range | 124 | 12th May 2013 01:02 PM |
| Tang Band W3-881SI line array problems | charliepuch | Full Range | 29 | 21st February 2013 11:08 AM |
| FS: (2) Tang Band W2-845S w/ Enclosures | speaker | Swap Meet | 1 | 2nd August 2012 11:23 PM |
| Tang Band W3-881SI Line Array Help | kctess5 | Full Range | 16 | 8th December 2011 10:25 PM |
| Tang Band Enclosures | Relax | Multi-Way | 1 | 15th November 2005 02:37 AM |
