Designing Tang Band 881si Enclosures - Page 4 - diyAudio
Old 22nd February 2013, 04:48 PM   #31
cogitech's Avatar
tuxedocivic,
Our experiences with the drivers are polar opposites. You keep laughing and I'll keep enjoying mine. I am quite certain that if you were to hear mine, you would not laugh.
BTW, I have not yet had the time to move them from the bedroom to the living room for a measurement session, but hope to do it soon.
Old 24th February 2013, 12:56 PM   #32
So maybe I'm just feeling less adventurous today, but I'm thinking now that maybe I'll just build the TABAQ with these and try something "new" with the next set. These would replace the built in speakers on the TV probably. I could try with 3/4" ply. They are not the cool bookshelf speakers I had in mind, but maybe I'll try for those later and if the TABAQ has good sound, I'd have something to compare to.
Gerrrr.... I feel like I'm lowering my standards by copying another design. Maybe my blood sugar is low. Time to eat.
Old 24th February 2013, 01:17 PM   #33
xrk971 is offline xrk971  United States
xrk971's Avatar
Wally,
Build the folded Tabaq, it is almost bookshelf size at 15 in tall x 10 deep x 4 in wide (internal dim).
Old 24th February 2013, 03:49 PM   #34
cogitech's Avatar
Indeed. I agree.
And Wally, there's no shame in using proven designs. That's why they are shared here, and the vast majority of DIY builds are from proven designs.
Go for it and then post your results!
Old 24th February 2013, 04:05 PM   #35
I'm much further along in my understanding and plans due to the great folks here. Thanks guys. I might have mentioned before that I had my gallbladder out and then a weak later went in for a hernia repair, so I've been needing something to keep my mind active. A foray into speaker design ideas (and well dreaming about the new Nikon D7100) has been most entertaining and has really helped pass the time. I can't lift anything above 20lbs, so I won't be in the workshop in the coming weeks, but when I do get out there and put these little drivers in something I'll be sure to post back. Thanks again and happy listening,
Seth
Old 24th February 2013, 04:50 PM   #36
xrk971's Avatar
If you can pick up a razor and a glue gun you can make speakers out of foam core. You can do it in your bed room or kitchen table. Lots of fun, learn a lot about the different designs, and they even sound good. When able, build the ones you like in wood.
Old 26th February 2013, 10:15 PM   #37
russo is offline russo  Portugal
This seems to be a simple way to get into DIY speakers, and then into DIY amps, but I can't find a shop in Europe that sells the Tang Bands, and buying from Parts-Express will be pretty expensive, because there is a minimum fee of 50$ in parts to ship overseas, and at that value I will be ripped by the customs
Any one knows some shop in Europe that has this speakers in stock?
Old 26th February 2013, 11:12 PM   #38
Russo,
Here is a link to the tang Band site with their distributors
Tangband Speakers
This website in Germany has Tang Band drivers (3" and 4")
Breitbandlautsprecher - Lautsprechershop von blue planet acoustic
You might try eBay in Europe as well. There are other drivers with a similar design and Thiele Parameters. Fostex is a brand that is distributed in Europe and will have a comparable 3" driver.
Old 26th February 2013, 11:15 PM   #39
guangui is offline guangui  Puerto Rico
It's the same subject, so I hope is not a thread hijack...Anyways, all my DIY projects have been copied from proven designs (ie. uFonken), OB, and BR enclosures. In order to learn other type of enclosures, I started reading on TWQT, and did a simple design, which I will make of Foam Core to try it. The W3-881SI is the driver for this design. My question is on dampen. Should I line with wool, and if so where? Or, should I use polyfill only (T1 area I would gather)? Or, should I use both? BR I just line completely, but not sure about TWQT.
Old 26th February 2013, 11:16 PM   #40
BTW, drawing is not to scale.
Tang Band W3-881SI line array problems charliepuch Full Range 30 6th January 2015 10:20 PM
"nanoTower" - Tang Band W3-881SI cogitech Full Range 142 8th September 2014 10:20 PM
FS: (2) Tang Band W2-845S w/ Enclosures speaker Swap Meet 1 2nd August 2012 11:23 PM
Tang Band W3-881SI Line Array Help kctess5 Full Range 16 8th December 2011 10:25 PM
Tang Band Enclosures Relax Multi-Way 1 15th November 2005 02:37 AM
Copyright 1999-2017 diyAudio
