How much stock should I put in these simulations
Old 12th February 2013, 02:27 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default How much stock should I put in these simulations
I used Diffraction & Boundary Simulator 1.20.
First off I calculated the golden ratio position in my open baffle and did a sim.
Then I used the NoBox plan. i.e. 90cm from floor and center of the baffle.
The result of the simulations is attached.
Driver is Visaton B200.
I noticed that there was a dip around 1kHz with the "nobox" placement and a bump before. The Golden Ratio graph looks less ragged.
If you can see the speaker cone move...it's not hifi.
Old 13th February 2013, 07:42 AM   #2
Bump.
Verstuurd van mijn GT-N7000 met Tapatalk
Old 13th February 2013, 09:42 AM   #3
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Short answer: it depends. Technically an offset is usually preferable (although golden ratio is a bit of a myth in some ways). However, you have to factor room response into these things, which usually screw things up below ~300Hz, and the polar response of the drive unit. The B200 has a rapidly narrowing power response as frequency increases, & while this has it's obvious drawbacks, it does tend to render it a little less vulnerable to some (some) baffle effects.
Old 13th February 2013, 10:46 AM   #4
Thanks Scottmoose. I'm aware of the offset usually being preferable. I have an old Phillps document where they suggest that. The golden ratio was just a starting point. But seems at least from a simulation aspect to have one of the flattest responses.
Anyway thanks for your reply.
Old 13th February 2013, 11:11 AM   #5
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hi Bas, did you try the driver centered at the same height as the golden ratio one? I've found with BDS that the vertical position on the baffle can make a big difference.
I read once somewhere (I think it was duntechs site but I checked there and didn't see it) that the particular designer had moved away from asymetric baffle placement due to negative effects (I think from memory on imaging). I ended up going with centre placement after reading that.... I wish I had the reference...
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 13th February 2013, 11:32 AM   #6
Hi Tony,
The sim with golden ratio height. But centered.
Bas
Old 13th February 2013, 11:50 AM   #7
xrk971 is offline xrk971  United States
xrk971's Avatar
Bas,
Where do you get this software?
Thanks,
X
Old 13th February 2013, 11:54 AM   #8
Hi X,
Loudspeaker Design Software
Scroll all the way down.
Bas
Old 13th February 2013, 02:18 PM   #9
GM is offline GM  United States
GM's Avatar
Using your baffle as a monopole measured at the old 4 ft standard distance and setting the room boundaries to '0' to mimic a corner, calculating x = 15.41", y = 27.4" looks close enough for me; ditto as a dipole 4" from rear wall and measured 45 deg off axis horizontally.
With the rest of the boundaries missing though, not to mention another speaker, furniture, etc., it's accuracy will rapidly degrade except over a narrow BW.
Still, a useful tool, especially for near-field apps.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 14th February 2013, 03:14 PM   #10
Thanks.
How much stock should I put in these simulationsHide this!Advertise here!
how accurate are the box simulations? scampo77 Car Audio 20 3rd November 2009 04:06 AM
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 09:06 AM
Seas L15 simulations Khron Multi-Way 3 11th April 2006 04:38 AM
Xamp-simulations problem_s grataku Pass Labs 25 31st July 2003 05:10 PM
Protel simulations Kees Solid State 2 12th November 2002 03:47 AM
Copyright ©1999-2017 diyAudio
