Nearfield PC Speakers, which driver?
Old 18th February 2013, 10:37 PM   #61
guangui is offline guangui  Puerto Rico
Does the front baffle gets lined with wool felt, or just the back, top, and sides???
Old 18th February 2013, 11:45 PM   #62
chrisb is online now chrisb
If you're referencing the little microFonken design, our approach is to line as much of all internal panels as possible without blocking any internal vent apertures, as well as leaving some margin of breathing room around the driver.
kinda burnt out - taking a break
Old 18th February 2013, 11:51 PM   #63
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
On the uFonken?
all sides including baffle & the bottom. Do not obstruct the vent entrances
dave
edit: Chris beat me to the punch
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th February 2013, 03:36 AM   #64
Originally Posted by planet10 View Post
On the uFonken?
dave
Thanks! They are lined allright...Front, back, top, bottom, and sides. Vents are not obstructed. Made a foam core model, then will build 12 mm baboon plywood cabinets. It was quite a learning experience working with foam core, hadn't done that since my college years (1987 - 1992). Not having a good pulse didn't make for really straight cuts, the first enclosure had some gaps larger than the usual hairline; sealed with epoxy. The second was much better, there are some hairline gaps, but will also seal with epoxy. In order to cover the imperfections I will prime and paint with a stone textured spray paint. Here is a picture of the pair.
Old 19th February 2013, 10:35 PM   #65
Here are pictures of the finished enclosures. 2-Part Epoxy was used to seal a few hairline and not so hairline cracks in between panels. Let's say my pulse is not the same as many years ago (need to buy a cutting wheel). After the Epoxy cured, in order to cover the marks left by Epoxy and cutting, I applied Primer then painted with textured stone paint. For the first time I will say that is not that bad.
Nearfield PC Speakers, which driver?Hide this!Advertise here!
Best Nearfield DIY speaker for PC listening thisisvv Multi-Way 73 25th September 2012 05:09 PM
Help ! Fullrange speakers for Nearfield listening jtjy Full Range 7 4th October 2010 11:18 PM
Suggestions for high efficiency nearfield speakers mrevie Multi-Way 8 29th August 2009 05:20 AM
best diy nearfield speakers for <300 shipped thadman Multi-Way 0 25th September 2006 11:28 PM
Need Help Getting Started - Nearfield Speakers alex douglass Multi-Way 20 4th October 2001 03:56 PM
