#31 |
Planet's recommended connectors are the ones I ordered from PE without knowing they were a favorite for the uFonken. When I saw them the other night, they just made sense. Direct wiring a uFonken sounds like common sense, but I will take these speakers to other places, and because wire runs are not always the same I rather have connectors.
For those of you interested in good quality binding posts for larger speaker projects, PE has a buyout sale of Mirage speakers cups with three different post options. One has isolated binding posts, the other has nickel plated posts, and the other has gold coated posts. I have had lots of experience with elector nickel plated (ENP) actuators, and they are very non-corrosive. |
#32 | |
I have these and wondering if it would work. anyone? gychang
-- Good sound from Phoenix, AZ
#33 |
frugal-phile(tm)
None of which i would use over what you got.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#34 |
#35 |
frugal-phile(tm)
Even for larger speaker projects.
dave
#36 | |
#37 | |
When you designed the uFonken, were you able to follow the Onken design guideline of trying to maintain vent csa of 90% of Sd? Or is that not really necessary? I am just unable to get anything like that when using the Onken calculator even with FF85WK. Anyhow let me know if my TC9FD Onken design seems reasonable. Thanks X mh-audio.nl - Home |
#38 |
They're not Onkens. They just look like them. In reality, the alignment is heading in almost the reverse direction to the traditional BR / Jensen Ultraflex / Onken where the object is to use the massive vent system to provide maximum efficiency at Fb. Dave is using the friction of high aspect ratio vents to provide a near-aperiodic alignment.
#39 |
#40 | |
| Best Nearfield DIY speaker for PC listening | thisisvv | Multi-Way | 73 | 25th September 2012 04:09 PM |
| Help ! Fullrange speakers for Nearfield listening | jtjy | Full Range | 7 | 4th October 2010 10:18 PM |
| Suggestions for high efficiency nearfield speakers | mrevie | Multi-Way | 8 | 29th August 2009 04:20 AM |
| best diy nearfield speakers for <300 shipped | thadman | Multi-Way | 0 | 25th September 2006 10:28 PM |
| Need Help Getting Started - Nearfield Speakers | alex douglass | Multi-Way | 20 | 4th October 2001 02:56 PM |
