Fostex FE126En Build - Page 3 - diyAudio
Old 13th February 2013, 10:49 PM   #21
Wow Chris,
thanks very much I will give the running in a good crank up as you suggest.
The speakers have just been put on a bookshelf to be run in out of the way, they will not be used on a book shelf but on Partington Dreadnought Stands.
Old 13th February 2013, 11:04 PM   #22
xrk971 is offline xrk971  United States
xrk971's Avatar
Those must be some stands to be named after warship featured in Sherlock Holmes' 'The Partington Plans'...
Old 13th February 2013, 11:56 PM   #23
chrisb is offline chrisb  Canada
indeed they are
... so, not as easy at it sounds, this letting go thing
Old 14th February 2013, 01:44 PM   #24
chris661's Avatar
Originally Posted by eldarvanyar View Post
Wow Chris,
You're welcome.
You might need more BSC if they're gonna be away from walls.
Drop all the sliders above ~500Hz by an extra decibel or two, see how you find it.
Chris
Old 14th February 2013, 03:03 PM   #25
Originally Posted by Scottmoose View Post
Re is the actual value (7.2), not the nominal impedance (which means nothing). The amount of attenuation you enter is the number of dB you need to lose from the output. In this case, I'd aim for the full 6dB since you're not just needing to compensate for step loss but the inherently rising response of the 126 drive unit. The tradeoff for obtaining a balanced response is that total sensitivity drops.
More realistic values are 1.8mH paralleled with 7ohms in the hot lead.
Hi Scot,
I have tried to send you an email at Woden Designs but it keep bounces back.
I have questions about the Woden Valiant to build later in the year.
Can you advise where to email?
Lee
Old 14th February 2013, 06:56 PM   #26
Hi Scot,
Lee
Lee - as mentioned above, I've built the Valiant (perhaps the first pair?), as well as BK12m, and many pairs of FH3, and might be able to answer some simple questions by PM.
Note that Scott's time is rationed more tightly than some of us, and there have been some server issues with the woden site email - but he does monitor the forum, and may be able to contact you.
Old 14th February 2013, 08:03 PM   #27
frugal-phile(tm)
planet10's Avatar
Hi Scot,
Lee
Use his frugal-horn.com email for the short term. Woden design was moved on the weekend and i still don't have the new email sorted.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th February 2013, 12:17 AM   #28
Hi Chris, sent you a PM
Fostex FE126En basket stabilization jazzminded Full Range 3 4th January 2013 09:55 AM
pair of Fostex fe126en with enable bigaudioscotto Swap Meet 2 25th April 2011 11:59 PM
old fostex fe126e vs new fe126en experiences?? gioz Full Range 3 14th December 2010 07:19 PM
Fostex FE126En cabinet ziocalepino Full Range 6 22nd May 2010 08:55 AM
Planet10's Fostex FE126eN... chops Full Range 59 7th February 2009 02:24 PM
Copyright 1999-2017 diyAudio
