OB - what FR to choose with Tesla woofers
Old 6th February 2013, 09:11 PM   #1
misok is offline misok
Question OB - what FR to choose with Tesla woofers
Hi. I've seen fullrange OBs with 15''helpers down there considered a fullrange approach so i hope im in the right sub-forum.
My not so clear question : I'd like to build an OB with a fullrange running 6-8" with a bass driver low-passed 150-200Hz 1st order do match a 2w tube amp. I got a beautiful pair of vintage 14" alnico Tesla ARO835, 4Ohm . But im not sure of FR selection and its impedance / implementation / safety.
id like to run the FR 'undisturbed' so it points to the paralleling the speakers. Does it make sense (quality-wise) ? i want to use its natural bass freq falloff and mate the woofer in that area. but adding a parallel 4Ohm FR would make 2Ohms which seem quite low for the amp.. maybe. Should i search for 8Ohm FRs ? How is it usually done when people use 4ohm helpers with FR-s ? Connecting in series or adding resistors (power loss) are the only solutions ?
thank you
m.
just a snap of new babies on a testing rig
Old 7th February 2013, 12:07 AM   #2
lousymusician is offline lousymusician  United States
Unless your amp has a 2 Ohm tap, I'd put them in series.
My OB's use two 8 Ohm, 15 inch drivers wired in series, driven from the 16 Ohm tap of my modified Stereo 70. I couldn't say why, but they sound better than they did in parallel from the 4 Ohm tap. The system is bi-amped, so the imdeance difference between the woofers and full-ranger is not important.
How sensitive are the Teslas?
Bill
Insert witty signature line here.
Old 7th February 2013, 12:18 AM   #3
Andrew Eckhardt is offline Andrew Eckhardt  United States
The "obvious" solution that suggests itself is to start with a first order high pass on the 4 or 8 ohm fullrange as well. That allows the load impedance to stay above 4 ohms throughout the band. You already know that your fullrange isn't going to do anything useful below 150 next to those woofers. Somebody well respected once said something like, "It has a capacitor in it. Deal with it".
Old 7th February 2013, 07:42 AM   #4
Thanks for reactions.
Primarily, I'd like to know, if i can use a single amp (for low-level, almost nearfield listening) without tradeoffs, and then if series connection of FR and the helper woofer isn't somewhat inferior to the parallel. There seem to be contradictions, i've seen few cases of preferring series, elsewhere something like 'no series please here'. It looks i have to try and listen.
Teslas should be 95db.
Old 7th February 2013, 10:01 AM   #5
it should look similar like this
Tiny Alnico Open Baffle
but i'm a bit confused. included crossover pdf looks like parallel to me and in the text is mentioned 'series'. i also dont know the idea behind choosing 16 / 8 ohm. is it related to 2 different versions of both drivers ?
Old 9th February 2013, 03:17 PM   #6
barackuda is offline barackuda  Slovakia
barackuda's Avatar
Hi Misok...
I am from Martin Slovakia
I have the same alnico driver, but unfortunately only one. Do you know where can I get second one ?
Danny
OB - what FR to choose with Tesla woofersHide this!Advertise here!
New to FR and OB forsakenrider Full Range 15 1st April 2011 02:08 PM
Binding Posts on FR OB kach22i Full Range 19 13th February 2011 04:20 PM
Vintage Tesla Alnico Woofers to sell - ARO 942, ARO 932 derik736 Swap Meet 10 1st May 2010 03:01 PM
My FR OB idea Ppasco1018 Full Range 16 29th October 2009 09:53 PM
Copyright ©1999-2017 diyAudio
