Best full range driver between 50-10.000Hz for a 3way system
Old 6th February 2013, 03:07 PM   #71
murphythecat8 is offline murphythecat8  Canada
Ive build my 3-way with all good quality drivers (I tried to use the best bang for the buck), it costed me with the wood and everything, 1k.
You should not build a speaker around the eminence, open a thread in multiway and ask them what they think.
Old 10th February 2013, 04:26 AM   #72
Godzilla is offline Godzilla  United States
Godzilla's Avatar
>>> Godzilla seems to like the Beta 12LTA. Personally, I don't. But who am I to point to a graph and say he's wrong.
Thank you Tux. You are a gentleman.
I thought I responded to this already about the 12lta but I guess I did not click the post button... I use this driver on an open baffle. I've built my main system around it. I own Fostex and TB and they are also excellent but there's something about the 12lta that allows me to forget about the system and listen to the music. It does not go deep enough in a sealed (or ported) 2.5cf cabinet. I've read it's been used with good results in 4 and 5cf cabinets but that's larger than I wanted in my home. I think it works well on open baffle and in a small sealed cabinet down to about 150Hz. You will need a subwoofer and a helper tweeter somewhere after 10kHz. But the driver pumps out 97db per watt and if you cut out the dustcap it will sound smoother than in stock form. It's a bit ragged but covers a large portion of the music without a crossover. There are measurements on the forum somewhere that coincided nicely to my listening impressions. I love the driver. It easily and effortlessly fills a room with sound. Tailor to taste with bass and treble support... and enjoy!
I would not shy away from Eminence drivers for the home. They may not be the most refined sounding drivers but they are efficient, well made and certainly pump out the volume. They are built differently than the more fragile drivers we typically discuss and they do sound different.
After spending years on trying to build a flat sounding system and realizing their are too many variables to overcome (my personal conclusion... your's may be different) I decided to try Eminence and for me it was a great choice.
Zilla
Best full range driver between 50-10.000Hz for a 3way systemHide this!Advertise here!
need help with a full range system Larkoth Full Range 5 9th December 2012 04:12 PM
Full range driver in a small speaker system exeric Full Range 18 7th April 2012 09:38 PM
Simple, Inexpensive, yet Decent Full Range/Single Driver system? dsavitsk Full Range 11 16th August 2006 11:40 PM
4-5" driver 50-10,000hz chuck55 Multi-Way 10 23rd June 2006 07:00 PM
PEAK FULL RANGE 12TX-50 DRIVERS - Are they worth anything? ozynigma Full Range 0 27th April 2004 08:47 AM
Copyright ©1999-2017 diyAudio
