Best full range driver between 50-10.000Hz for a 3way system
Old 4th February 2013, 09:10 AM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
myself and TVRgeek have been discussing a similar topic over in the multiway forum. Our desired bandwidth is a little smaller (600-6k or so). Within these constraints its a little easier. Im thinking of using an alpair5, and TVRgeek is looking at a fountek, the 89 i think. The limit with these is their sensitivity. We are both aiming to keep the FRs breakups out of the mid band. Provided excursion isnt a problem there is nothing preventing a wider midband, but i imagine that going with higher efficiency FRs could present more difficulty, particularly with matching polar patterns with larger drivers.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 4th February 2013, 09:20 AM   #12
SpirosZ is offline SpirosZ  Greece
The 600-6k range could be an option if I was going to use a woofer instead of a subwoofer but there is a conflict with the center channel that rules out that option.
If I was in your shoes I would be also looking at Fostex FF83WK with a 10" SB Acoustics woofer.
Old 4th February 2013, 09:21 AM   #13
Originally Posted by talaerts View Post
Well, contrary to my own expectations, the FF225WK is not shouty when played unfiltered. It is pleasant and warm sounding. The B200 indeed has a reputation of being somewhat difficult to handle.
Thank you for that info. So it seems that the Fostex could be one of my options.
Old 4th February 2013, 10:08 AM   #14
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
What about the cheap MA CHR-70? Not sure where it rolls off f3 sealed but it might be a good bet
Old 4th February 2013, 10:12 AM   #15
+1 for that .
Old 4th February 2013, 10:54 AM   #16
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Does 55 to 5.5kHz at 91 dB efficiency work for you? Here is a neodymium driver that may work and has been suggested in an mtm setup with good results reported.
Aura NS6-255-8A 6" Paper Cone Neodymium Magnet Woofer 299-030
Old 4th February 2013, 11:24 AM   #17
How much better a CHR70 can be (if it is any better) from the CHP70 that I have already bought and ruled out (along with all the 4" & 5" fullrange drivers available)?
The requested useful range of 50-10.000Hz can actually shrink to 80-8.000Hz or even to 80-5.000Hz but I want the effortless 80Hz of a large cone and not the stressed and probably distorted 80Hz of a 4' or 5" driver.
Old 4th February 2013, 11:50 AM   #18
talaerts is offline talaerts  Belgium
Since you filter actively, you could cross the extended midrange at, say, 150 hz.
Then you could opt for the incredible Alpair A12P which in a way would be a good investment as you won't need a tweeter and associated filter components. The Alpair is very, very good, in my opinion a class higher than anything I heard from Fostex except a few limited editions.
Old 4th February 2013, 12:14 PM   #19
That one looks like the perfect driver for an ultra low cost speaker in general.
However even though my budget is not huge I would rather spend some more money on the main and most important driver of the system.
Having said that at $9/ea I may buy 3 of those just to try them.
I am only afraid of spending all my budget on possible low cost alternatives and not get the sound I want in the end (I have the tendency to buy several cheap stuff just to try if they are good for the money; I have already bought a pair of low cost 8" drivers only because they were cheap and had great reviews. They don't meet my criteria either so now I have to find a use for them).
Old 4th February 2013, 12:22 PM   #20
The Aplair A12P could also be a choice even though I would rather cut the sub under 100Hz.
How does an A12P crossed at 100Hz would compare to an FF225WK + tweeter with a 6db/octave XO @~5-8K?
The Alpair is a 6" driver right?
Best full range driver between 50-10.000Hz for a 3way systemHide this!Advertise here!
need help with a full range system Larkoth Full Range 5 9th December 2012 03:12 PM
Full range driver in a small speaker system exeric Full Range 18 7th April 2012 08:38 PM
Simple, Inexpensive, yet Decent Full Range/Single Driver system? dsavitsk Full Range 11 16th August 2006 10:40 PM
4-5" driver 50-10,000hz chuck55 Multi-Way 10 23rd June 2006 06:00 PM
PEAK FULL RANGE 12TX-50 DRIVERS - Are they worth anything? ozynigma Full Range 0 27th April 2004 07:47 AM
