Old 3rd February 2013, 05:33 PM   #1
SpirosZ is offline SpirosZ  Greece
Default Best full range driver between 50-10.000Hz for a 3way system
I 'm not sure if I should post this here since I am not talking about a single full range driver speaker but rather a full range driver based, 3way speaker.
Mods are free to move the thread to the multiway forum if necessary.
I have the feeling that my other project is not going to be exactly what I am looking for so I am already looking for alternatives.
The idea is quite simple.
I want one driver to reproduce the majority of the audible spectrum with helping drivers in the low and high end of the spectrum.
That way I can use a larger more efficient full range driver with better dynamics.
I want a simple 1st order crossover network between the full range and the tweeter (cross at around 8KHz) and a pair of active subwoofers to reproduce the low end (cross at 80Hz or lower).
The drivers I have in mind are the Visaton B200, Fostex FF225WK, Audio Nirvana cast 8", Dayton PS220, Tang band W8-1808, Tang band W8-1772, but there may be other drivers that I don't know about.
This project looks like it is going to cost a lot more than the previous one I was looking at so it has to be much much better one.
Old 3rd February 2013, 05:50 PM   #2
adason is offline adason  United States
adason's Avatar
there must already threads like this...fullrange as mid in 3-way
need help with a full range system Larkoth Full Range 5 9th December 2012 11:12 AM
Full range driver in a small speaker system exeric Full Range 18 7th April 2012 04:38 PM
Simple, Inexpensive, yet Decent Full Range/Single Driver system? dsavitsk Full Range 11 16th August 2006 06:40 PM
4-5" driver 50-10,000hz chuck55 Multi-Way 10 23rd June 2006 02:00 PM
PEAK FULL RANGE 12TX-50 DRIVERS - Are they worth anything? ozynigma Full Range 0 27th April 2004 03:47 AM
Old 3rd February 2013, 06:20 PM   #3
These threads may look similar but they are not. I have already check them.
I am looking for an 8" driver with good dynamics that is still in production and I can find in Europe.
Old 3rd February 2013, 08:35 PM   #4
chris661's Avatar
Budget?
Cabinet size?
How loud does it need to go?
Old 3rd February 2013, 09:18 PM   #5
The drivers I mentioned are already above my budget.
However I could probabaly stretch it to fit if i am going to get the sound I want.
Cabinet size doesn't matter that much as soon as it is not huge but speakers will have to stay close to the rear wall.
I would like them to be able to hit 100db at 3 meters even though I do not usually listen that loud.
Actually around 95-98db will be fine but its good to have some headroom.
Old 3rd February 2013, 09:59 PM   #6
Whoaaaah, 50 to 10k?!?
A cheap option might be the Beta12LT!
Speaker Detail | Eminence Speaker
High eff, wiiiiiide band! 12"
Gets down to 50 in their 4cuft vented cab:
Beta_12LTA_cab.pdf
And 4cuft isn't that big if you consider it a "stand" to get the driver up to ear height! ;-)
The 1.75 sealed looks pretty sweet but rolls off at 80Hz but it's only 9dB down at 50
Godzilla's fallen in love with his and it's big enough to get close to 50Hz. There's a notch filter for the stock driver but apparently replacing the dustcap with a phase plug helps. (.. almost there myself, just have to find something to work as a plug ... hmmmm ... 1/2 a Kinder Egg! No, ... it'll melt ...)
Here's me playin' with mine open-baffle style!
Do the usual tricks to deal with the cheap stamped metal frame and other issues: baffle and/or magnet mount, notch filter, putty/deaded basket, phase plug, breakup back-of-driver to basket reflection, 99cent trick, painting whizzer, ... , ... , adding spokes to the driver, ..., ..., madness!
Jeff
PS I think there are other less expensive 'pro' options too! I recall the Legend12 or some other guitar speaker being used as a fullrange.
Old 4th February 2013, 06:08 AM   #7
Maybe I went too far with the 50Hz .
I just want to be able to cross it nicely with a sub.
I don't really want the driver to perform well under 80Hz or over 8KHz, I just want it to behave. If there is severe cone brake up above 8k that needs to get filtered with a steep Xover slope, it's not for me. If it bottoms out at 80Hz and needs to be cut off at 100Hz or more so save it's life, it's not for me.
I can find a tweeter with a very low Fs and cut it with just a capacitor at 5K and then do the same with just a coil on the full range. If the driver doesn't have huge problems between 5-10K it should be a fine transition.
The same with the low end.
A 4" or even a 5" full range will set the limits of the dynamics.
They certainly can't match a 6.5" an 8" or a 10" midbass.
However I wouldn't like to go beyond 10" on that one.
I believe that even a 10" driver that can match my criteria will have to cost several times more than my budget allows. Let alone a 12".
That's why I am looking at the 8" drivers.
I also have the feeling that I have more chances to find what I want on a 6.5" than a 10" unless I raise the budget considerably.
And of course low cost pro speakers are simply out of question. The only pro speakers that I could ever listen to cost a few thousand dollars each (call me Nexo).
Old 4th February 2013, 08:02 AM   #8
I found that the FF225WK is very nice sounding, no fatigue. It has in fact solid bass on its own. For most music use you don't really need subs. Of course, if you actively filter then the speaker can put more effort in frequencies of say 100 hz upwards. But unless you already have active subs and filters, leave these aside for now.
The FF225WK has enough widerange to allow for many experiments with tweeters.
If in budget I would investigate entry level planar type (ribbon, magnetostatic etc) tweeters with it.
Old 4th February 2013, 08:56 AM   #9
I already bought a Peerless XLS 830452 sub to try out. If it proves to be good I will get one more.
I also found localy a used JLaudio 12W6v2-D4 at a reasonable price that I think about buying if the XLS is not good enough so there is definitely going to be at least one active sub in the system.
I have also bought a pair of CHP70s that I can use as surrounds (they were originally bought to become the basic driver for a 5.1 HT setup) or move them in my office as PC speakers.
The (8"?) full range will be used for L/R and center speaker with the aid of a tweeter and a 1st order XO.
I also think about mounting the tweeter concentrically with the full range (The Vifa XT25SC is under investigation right now but I don't fancy it's off axis response) so that the center channel can be compact in size.
The FF225WK was probably my first thought along with the Visaton B200 but there are a few more drivers to consider like the Audio Nirvana 8" and a few others.
Also looking at the FR charts of the first two I can see they are "shouting" a little in the upper mids-lower treble so maybe one of the other drivers is more appropriate as I don't think I am going to like the mids shouting. I just can't find enough information about them.
It's really difficult to make decisions when you don't have the chance to actually hear any one of them and you have to decide by information interpolation.
Old 4th February 2013, 09:09 AM   #10
Well, contrary to my own expectations, the FF225WK is not shouty when played unfiltered. It is pleasant and warm sounding. The B200 indeed has a reputation of being somewhat difficult to handle.
need help with a full range system Larkoth Full Range 5 9th December 2012 03:12 PM
Full range driver in a small speaker system exeric Full Range 18 7th April 2012 08:38 PM
Simple, Inexpensive, yet Decent Full Range/Single Driver system? dsavitsk Full Range 11 16th August 2006 10:40 PM
4-5" driver 50-10,000hz chuck55 Multi-Way 10 23rd June 2006 06:00 PM
PEAK FULL RANGE 12TX-50 DRIVERS - Are they worth anything? ozynigma Full Range 0 27th April 2004 07:47 AM
Copyright ©1999-2013 diyAudio
