Mark Audio A12P SuperPensil Buildlog - Page 5 - diyAudio
Old 6th February 2013, 12:17 PM   #41
xrk971 is offline xrk971  United States
xrk971's Avatar
They look great! Very nice job. If they sound this good before break in, you are in for a real treat then. Those are some big speaker boxes.
Old 6th February 2013, 12:29 PM   #42
Scottmoose's Avatar
Nice work.
Old 6th February 2013, 12:30 PM   #43
Scottmoose's Avatar
No they're not.
Old 6th February 2013, 12:30 PM   #44
Thanks!
Old 6th February 2013, 12:31 PM   #45
Originally Posted by Scottmoose View Post
No they're not.
I think they are the upper limit to what would be acceptable in that room.
Old 6th February 2013, 03:47 PM   #46
glt is offline glt  United States
Thanks for sharing. I too got a pair of Alpair 12p already in a bookshelf cabinet. The details coming from the speakers are amazing. Since I had been using a KEF uniQ, at first I thought there was something wrong with the speaker...
Pretty amazing that with all the high tech material available, the Alpair12 uses paper for the cone.
www.hifiduino.wordpress.com
Old 6th February 2013, 04:34 PM   #47
Scottmoose's Avatar
What high technology materials are you referring to? Papers are not all created equal; composition of the mix, thicknesses and structure are all critical.
Old 6th February 2013, 04:36 PM   #48
vinylkid58's Avatar
Congratulations on your build Ron.
Some of us like paper.
jeff
Old 6th February 2013, 04:37 PM   #49
It has been proven time and time again that paper is the best material for the cone. As Scottmoose hit on, the quality and implementation are key.
Old 6th February 2013, 04:58 PM   #50
Scottmoose's Avatar
Actually it hasn't. Again, it's a matter of implementation and design requirements.
Many people like paper cones, and they often make many assumptions about cone materials. But 'best' is a target that varies depending on what it is you want to do. For example, W.E. etc. back in the day preferred metal. But there are some things that paper cones can do that are harder to do with metal cones, and visa versa. Same applies to many other material types. Cone profles and suspension design also play a major role in this. Take the current generation A12P under discussion here. The reason paper is used is that there aren't any other materials available that have the necessary balance of properties (stiffness, resonant characteristics, weight et al) that will achieve the desired response & efficiency with that cone profile -not any that are realistically affordable anyway. Kevlar, fiberglass, carbon etc. won't do it. Metal gets closest, but even then, weight goes up, efficiency down, & with the very flat cone profile and the way the suspension is designed, where the spider does the majority of the work, it runs into stability issues.
Avebury A12P build bqc Full Range 35 14th November 2014 12:07 AM
A12P bezel cover bqc Full Range 8 18th July 2013 02:47 PM
A12P MLTL's Toppsy Full Range 25 11th April 2013 04:17 PM
Any A12P owners out there? impuls60 Full Range 37 30th October 2012 03:27 PM
A12P break in question - mp9 Full Range 5 23rd July 2012 08:19 AM
Copyright 1999-2017 diyAudio
