Mark Audio A12P SuperPensil Buildlog
Old 3rd February 2013, 04:56 PM   #21
RonVinyl is offline RonVinyl  United States
A bunch more completed so far today, should have one totally done today! Just a couple more back supports to go. A quick run to Lowes to get the pieces to attach the back with.
Going to hardwire them through the port today to do a listen test. (No binding posts etc here yet.)
Old 3rd February 2013, 06:56 PM   #22
I have one cabinet fully glued up except for the back. Going to attach the back once this glue sets and mount the driver. Should make for a great listen test!
Thanks to Planet10, I will use CAT5 from the driver to the hookup. (I will just be running this out the front port for now during the test phase.
Old 3rd February 2013, 07:04 PM   #23
Here are some pictures from the build so far...
Old 3rd February 2013, 07:37 PM   #24
Couple more shots after the last clamps came off. Back is just tapped into place, no screws or anything yet. Fits like a glove. Stable too!
Todo:
  1. Trim Edges with Flush Trim Bit
  2. Roundover all edges
  3. Install Drivers
  4. Add PolyFill
  5. Test
Old 4th February 2013, 12:07 AM   #25
danvprod is offline danvprod
danvprod's Avatar
Listened to these tonight (well the left channel at least!). They are going to be a nice sound speaker! Impressed with this A12P drivers for sure.
Old 4th February 2013, 12:08 AM   #26
They were nice indeed. Thanks to danvprod for all the help!
Old 4th February 2013, 12:30 AM   #27
I need to figure out an effective way to keep the polyfill from reaching the port.
Old 4th February 2013, 01:21 AM   #28
mp9 is offline mp9  United States
Simplest solution, stagger two 1.25" dowels to form a Cross Brace just above the port but not with equal spacing from the next set of X bace'd dowels further up the cabinet. Although i do question whether three pairs of X braces would be sufficient bracing for a cab of that depth.
Old 4th February 2013, 01:24 AM   #29
Thanks, I will take a peek at my options... I might make the optional braces...
Old 4th February 2013, 02:25 AM   #30
That said it might be worth just making the hole-y braces in the original super pensil plans. I have enough wood to do so. Should be a decent improvement.
Mark Audio A12P SuperPensil BuildlogHide this!Advertise here!
Avebury A12P build bqc Full Range 35 14th November 2014 12:07 AM
A12P bezel cover bqc Full Range 8 18th July 2013 02:47 PM
A12P MLTL's Toppsy Full Range 25 11th April 2013 04:17 PM
Any A12P owners out there? impuls60 Full Range 37 30th October 2012 03:27 PM
A12P break in question - mp9 Full Range 5 23rd July 2012 08:19 AM
