Audio nivarna Super8
Old 1st February 2013, 10:27 AM   #11
gafhenderson is offline gafhenderson  United Kingdom
Originally Posted by col View Post
I had a play around with a pair of Super 8"s I picked up off ebay a while back. There is a few pictures here:
Audio Nirvana Super 8"
They are a good entry level fullrange driver for the price but the mids are hard to tame.
have you damped the stamped basket with anything? playing with other drive units with stamped baskets, it makes a huge difference to the sound.
think i also read somewhere on here, that there's a definite improvement between the cast frame super 8's and the stamped frame ones.
Old 1st February 2013, 02:12 PM   #12
GM is offline GM  United States
GM's Avatar
Ditto encasing the motor in open cell foam or felt and depending on how the motor is attached to the frame, adding a thick bead of epoxy to stabilize this joint/raise its resonance to make it easier to damp, though some folks prefer to fill this area with modeling clay or similar to try and push the resonances lower.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th February 2013, 01:04 PM   #13
kevner1954 is offline kevner1954  United States
your right NO H how stupid of me since I researched and built a set of pipes and only to loose them in a fire, Thanks
Old 10th February 2013, 03:13 PM   #14
R-Carpenter is offline R-Carpenter  United States
R-Carpenter's Avatar
I measured super 8 a couple of years ago for a customer. Qts came back much higher then declared. Don't remember which exact model it was but it sounded good OB and very muddy in the ported cabinet. Also, not sure if the specs changed over the years.
Distortions and CSD were quite nice for a paper driver. Much better then Fostex IMO.
But I would suggest checking TS on your own.
http://www.diy-ny.com/
Audio nivarna Super8Hide this!Advertise here!
audio nirvana super8 cabinets decision neazoi Full Range 23 4th February 2013 07:44 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
Information about Audio Nivarna tubeman813 Full Range 6 25th June 2010 04:11 AM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
ApexJr super8 fun theNoid Subwoofers 14 1st December 2006 07:16 PM
