Anyone interested in helping with a bookshelf and floor stander using E100HD?
Old 24th February 2013, 04:06 PM   #11
AnKoe is offline AnKoe  Germany
Originally Posted by R-Carpenter View Post
I didn't save the files as FRD or SE. Only measured E100HD to see how different it is from original JX92.
But the conditions are:
Driver measured free air on a 5'x10' baffle. Near field response is taken with 500msc gating, 262144 sequence length at 1cm.
Far field at 1m 7msc gating, 65535 length, spl adjusted for gain.
Response merged at 600hz.
Distortions are taken at .5m 2.9v input signal.
Are you familiar with Jeff Bagby's PCD?
Which part of ribbon tweeter response modeling do you find harder then let's say a dome tweeter?
With "raw data" I had some ascii table in mind. I will digitize the plot to compare it to my measured values.
I don't know the tool of Jeff Bagby. Usually I use a pencil a sheet of paper and a fortran compiler as design tools.
The amplitude and phase behaviour of dome tweeters can be modeled by a harmonic oscillator (equivalent to a second order high pass filter). By measuring the impedance, the resonance frequency and damping of the tweeter can be determined. In a crossover design, the tweeter behaviour can be used as a part of the high-pass filter (eg. one stage of a 4th order linkwith riley filter). Ribbon tweeters are more complicated to use. There is no direct possibility to link the ribbons resonance to the impedance and there are many artefacts caused by the chassis design that influence phase and amplitude.
Old 24th February 2013, 06:13 PM   #12
R-Carpenter is offline R-Carpenter  United States
R-Carpenter's Avatar
Jeff's crossover designer tool allows you to take graphic files, trace them and use them in the crossover design. You'd need FR, phase and impedance to produce a fairly accurate model. It's popular on Parts Express Tech talk and you could get your tutorial for it there.
As far as ribbon design. You can measure frequency response distortions and impedance of the ribbon tweeter just like any other tweeters, using software package like ARTA (free without "save" option) and get the minimum phase of the measured driver. Natural roll off of most of the ribbon tweeters falls together with a strong rear chamber resonances and in my experience, pass-band of the ribbon tweeter is limited by the crossover quite a bit higher from these troublesome areas.
Here's a couple of treads with measurements.
Fountek NeoCd3.5H Horn Tweeter
Measuring Raal 140-15D
I've measured a few other ribbons and find that the most difficult issue with them is the axial performance.
http://www.diy-ny.com/
Old 24th February 2013, 06:56 PM   #13
I had a look at the homepage of the tool. It sounds interesting, but since I am a linux user it is no option for me. Besides, it is not neccessary to have a specialized tool. You'll need just physics and mathematics.
Sure, you can measure the impedance of ribbon tweeters but the measurement is not sensitive to accustical properties of the ribbon. What you measure are mainly properties of the transducer. If you measure the amplitude and phase you get all information of the driver, but then you are not based on a physical model. That is what I meant with "difficult to model".
Old 27th February 2013, 09:17 PM   #14
hm is offline hm  Europe
hm's Avatar
Default TUBA
Hello,
someone in NL made it with E100HD.
feedback 5 tubaFB
look my measurements with JX92 here:
tubamess
http://www.hm-moreart.de
Anyone interested in helping with a bookshelf and floor stander using E100HD?Hide this!Advertise here!
Super High-End 3-way floor-stander gornir Multi-Way 122 23rd March 2017 03:46 PM
First DIY Build help. 3-way floor-stander. Elias318 Multi-Way 20 9th June 2012 12:18 AM
Fostex FE108EZ floor stander - hi SAF/WAF thoglette Full Range 13 16th May 2012 04:55 AM
Recommendation of speaker elements (2-way, floor-stander) onda Multi-Way 16 2nd November 2011 01:57 PM
floor stander speaker system zackkstar Multi-Way 1 12th June 2006 03:13 PM
