What can my amp handle
Old 19th January 2013, 09:25 AM   #1
Goodlagger is offline Goodlagger  Australia
Default What can my amp handle
I'm running a siliconray srk09 claimed 10w by two I'm wondering can I run two of these speakers in parallel
Old 19th January 2013, 09:26 AM   #2
Speaker specs
Old 19th January 2013, 09:27 AM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Google the specs on your amp to see if it can run 2 Ohms.
Old 19th January 2013, 09:28 AM   #4
It has 4 and 8 ohm taps only
Old 19th January 2013, 09:29 AM   #5
Can I mod it to run 2
Old 19th January 2013, 09:42 AM   #6
madtecchy is offline madtecchy  England
Why woul you want to run then in parallel... Just wire them in series and connect to 8Ohm Tap..
Old 19th January 2013, 09:46 AM   #7
But that would be 16 ohms I was thinking 2 8 ohm in parallel = 4 ohms connected to 4 ohm tap but would that be to Mitch for my amp to handle or would in not be worth it I was thinking double the speaker double the amount of air displaced ??? Am I wrong
Old 19th January 2013, 09:48 AM   #8
Oh I just checked the impedance I thought they were 8 ohm speakers so two in series it is sorry
Old 19th January 2013, 09:50 AM   #9
Am in the right track with two speakers is better than one or not
Old 19th January 2013, 10:18 AM   #10
xrk971 is online now xrk971  United States
xrk971's Avatar
That is an interesting driver, pretty low fs for how small it is. Can you get us the link to the driver? The basket looks like a vifa/peerless but it is not.
The specs show 4 ohms, if you want to get more spl with them then 2 in series for an 8 ohm amplifier. You will lose the nice point source nature of these drivers as full range speakers if you have more than one pointing forward towards listener.
What can my amp handleHide this!Advertise here!
how would you handle this a/b switching? thegnu Instruments and Amps 4 16th January 2009 02:10 AM
Anyone have a "handle" on the Yaqin EL34 X 2 SE AMP? John L Tubes / Valves 1 29th March 2008 06:38 PM
amp that can handle 600 watts subs Slamdunk Class D 13 23rd May 2007 10:49 AM
Best way to handle 25hz & down 2 Tempests johninCR Subwoofers 24 2nd October 2005 10:31 AM
Too hot to handle Panelhead Pass Labs 3 8th May 2003 01:10 AM
Copyright ©1999-2017 diyAudio
