SB 8 inch woofer sounds great on its own.
Old 19th January 2013, 02:41 AM   #21
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Wow you move quickly!!!
I'd start by raising them off the floor. Do you have a bigger inductor? That woofer has pretty flat impedance, but maybe a 10uF cap across it in parallel.
Old 19th January 2013, 02:52 AM   #22
xrk971 is online now xrk971  United States
xrk971's Avatar
Sootboots,
Nice job with the foam core cabinet. I think you are the first to do a 2 way since I started the foam core thread. Looks like fun and I can tell you like the sound. Speaker cabinets never weighed so little have they?
Old 19th January 2013, 03:09 AM   #23
sootboots is offline sootboots  Canada
I have a 5mH inductor here. Any suggestions?
John
Old 19th January 2013, 03:13 AM   #24
Paul Simon's "Rhythm of the Saints" is on right now and the imaging is the best I have heard yet in my 16x 20 living room. I am willing to give all of the credit to the MA 7.3 but the woofer and foam core must figure in there somewhere......
John
Old 19th January 2013, 03:29 AM   #25
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
John
It could introduce you in the realm of OB (open baffle)
Or any other application of a woofer which is 'cut' real low- so it
make happen the extension>sensitivity trade off .
With OB you lose lots of pressure in the bass because of acoustic
short-circuit
Which I doubt is present in foam enclosures, in multiple forms ( transparency
to the lowest frequencies , and selective and depending on the different paths
that sound travels with ...)
Old 19th January 2013, 03:38 AM   #26
Well, I don't know anything about open baffle, but if you also have a bigger cap I'd swap in the 5mH instead of the 1.5mH. I'd then bump up the 22uF for something about 50uF if you have it. Even two 22uF in parallel gets you 44. Once you have that I'd put the 1.5mH and about 5 to 10ohm resistor in series with it, and put that LR across in parallel with the alp7. So 44uF followed by 1.5mH + 8ohm going to ground.
A schematic would make more sense but I'm on my phone.
Old 19th January 2013, 03:40 AM   #27
The 1.5mH + resistor is to compensate for impedance in the alp7's low end which is required for the 50uF cap to do a proper job.
Old 19th January 2013, 03:43 AM   #28
Yeah
5 mH is good for making an HP more robust!
Difficulty arises, as 2nd order makes 180 phase rotation at output.
Just a tought.
BTW I'm using 8 and 10" paired with 2" as mid-tweeter
Old 19th January 2013, 05:21 AM   #29
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
...first order cross over consisting of a 1.5mH inductor on the woofer and a 22uF film cap on the MA 7.3
Somewhere 700-800 Hz (nominally). Part size is going to need to increase.
Try connecting those parts in series and see what happens. It may help, it may not. One thing it does is lock the 2 drivers together so that the LP = HP.
SB 8 inch woofer sounds great on its own.-a73-sb23-seriesx-gif
Try with what you have
A series XO has a parameter called Zeta that describes the behaviour of the electrical filters around the XO. Zeta = 1.0 = Butterworth (with the same text book RL values as passive). Raise the zeta you get a depression, lower it a hump.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th January 2013, 04:25 PM   #30
mor2bz is offline mor2bz  United States
u like this better than the pencil? what is an sb woofer ?
SB 8 inch woofer sounds great on its own.Hide this!Advertise here!
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 01:01 PM
4 inch driver sounds better than $1000 ror Full Range 101 9th November 2010 07:32 PM
Sounds like a great deal from a great guy mikejennens Chip Amps 0 3rd February 2010 12:17 AM
Pentode sounds great Cassiel Tubes / Valves 15 31st August 2008 11:23 PM
sounds great, thanks to everyone that helped. Richie V6 Chip Amps 6 1st January 2005 04:06 PM
Copyright ©1999-2017 diyAudio
