erich hartmann alpair 10.2 bookshelf speakers
Old 12th March 2013, 02:06 AM   #11
phivates is offline phivates  United States
REAL funny. Real men love their honey. Do. Don't do. Repeat.
Old 12th March 2013, 05:32 AM   #12
soundnovice is offline soundnovice
Originally Posted by chrisb View Post
I couldn't agree more - while few of us have had the opportunity to compare every possible permutation, I've experienced the larger MA drivers enough to say that with all due respect to the numerous designers of compact / bookshelf enclosures for the 10.2 (and for that matter 12P), these drivers truly blossom in a "full size" enclosure such as Pensil, M10A10, Silbury, etc.
Of course on those rare occasions when domestic concerns interfere with optimal enclosure design / placement ....
ya see, that's funny because .... well you know
pencils are not big and not small. just of the size that my room can take without complaining (in other words...allowed WAF! )
Old 12th March 2013, 08:46 AM   #13
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Hi Guys,
I'm using Erich's box design upstairs with MAOP 10 drivers. They are OK, bass is a little tight, the vent needs to be a little bigger but no time to re-calculate/re-make.
As per others comments, to get the best from the Alpairs, use a bigger box (Pensil et al.)
Cheers
Mark.
Old 13th March 2013, 05:17 AM   #14
do pencils increase SPL? i see similar MLTL by Bob (M10-A10) mentioned SPL to be 90dB which is 3dB more than the driver spec.
Old 18th March 2013, 09:25 AM   #15
today stuffed the boxes with 1" thick glasswool. not sure if this is too much but thats what i have at hand. there is considerable improvement compared to 1" think egg foam. glasswool does the job better!
i used 19AWG OFC wire for internal wiring and also for amp connection. is there any advantage going for lower AWG wire in this case?
Old 18th March 2013, 10:32 AM   #16
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Only in their operating band, at the bottom of the frequency range. It depends on how you measure them TBH. And the MA units are a little unusual compared to some others in that they're usually somewhat easier to drive than the bald figures might imply.
19ga should be more than sufficient for internal wiring by the way. As for fiberglass, I'm not surprised -acoustic foam (egg crate foam / whatever you like to call it) is rubbish as far as I'm concerned. One point though: you might want to get some muslin or similar stretched behind the driver to prevent fibers getting into it.
Old 18th March 2013, 11:18 AM   #17
thanks for muslin tip. despite of careful cnc cut baffle hole/flush mounting, still i feel there is edge discontinuity, so thinking to glue felt ring around the periphery of bezel edge. will this actually work?
Old 18th March 2013, 12:53 PM   #18
silverhairbp is offline silverhairbp  United States
Pantyhose works very good and is pretty much acoustically transparent.
erich hartmann alpair 10.2 bookshelf speakersHide this!Advertise here!
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 79 30th May 2018 05:22 PM
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Full Range 58 3rd November 2015 02:07 AM
New Bookshelf Cabinet for Alpair 10 (Gen 2) Musik007 Twin Audio 14 9th January 2013 07:25 AM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 03:19 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 06:14 AM
