#21 | |
I have never heard a back-loaded horn either. ![]() Maybe I should do a FH3 build and stick a couple of my EL70s in them so we can both hear a horn before going forward... |
#22 | ||
I would. If impractical, then you already know what I think, it just tends to underline it.
Excellent. Thanks Jim. Not sure how I missed that one. Quote:
#23 | |
![]() FH3-inspired Foam Core Mini Build And if you don't like how it sounds, you have only lost a day of your labor. If you like how it sounds, like I did, you have a set of nice sounding speakers that you can use in places where you ordinarily would not take a heavy, expensive speaker. ![]() Good luck with your decision. X |
#24 |
Very cool xrk! I saw that thread before but it is hard to believe foam core sounds good.
I might just do it. In fact, maybe I will build Silburys out of foam core, just for sh!ts n' giggles!
#25 |
Foam core Silbury's would be a sight to see.
#26 |
#27 |
Sorry for the thread hijack. If we continue with this line, we should take it up in the foam core thread.
For a quick and dirty foam core horn, you can butt-join the panels together with hot melt glue. The numerous channels on the inside provide a lot of supporting bracing underneath the panels so it will still be quite rigid. The exterior panels just need to be airtight and the hot melt glue joint does that very nicely. If you wanted, you can add a thin layer of paper on the outside of the butt joint with PVA glue and it will increase strength and rigidity and make it look like one big piece. Uline sells bigger pieces of foam core (96 x 48 inches in fact but they want $15/sheet and you have to buy a carton so it is prohibitively expensive). 48 x 96" White Foamboard S-11755 - Uline The Elmer's brand board which is really nice and perfect for exterior panels is available in 36 x 24 in size so that only 2 would have to be butt joined. But again, price may be prohibitive to buy a carton of 25. At least it is only about $4 ea or $100 a carton. But if you think about how many speaker projects you can make for the $100, it doesn't seem so bad... hmmm... http://www.dickblick.com/items/13202-2020/ Last edited by xrk971; 17th January 2013 at 05:16 PM. |
| "WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral | enantra | Swap Meet | 3 | 23rd December 2012 06:36 PM |
| 3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" | proxii | Multi-Way | 16 | 30th October 2012 12:43 PM |
| Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? | edbk | PC Based | 0 | 1st May 2012 02:40 PM |
| The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter | River757 | Multi-Way | 14 | 7th September 2011 06:41 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
