TL-box for BG20 Visaton
Old 26th January 2013, 05:27 AM   #61
Gost22 is offline Gost22  Bolivia
Banned
Thumbs up Simphony BG-20
Hi all!
See and enjoy!!
Old 26th January 2013, 08:54 AM   #62
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Gost,
The drawing looks good. I think you need to put the polyester wool damping in the closed end between the driver and the 101 mm corner. The damping wool in main space leading to opening is optional and will reduce bass output if desired.
Old 28th January 2013, 11:42 AM   #63
Banned
Hi xrk971!
Around speaker damping streanu see this web page: OrdinaThor_Loudspeakers_TQWT - Tapered Quarter Wave Tube alias Voight pipe - fullrange speakers, horn, high efficiency, tqwt, multiple arrays, general audio topics>, or OrdinaThor_Loudspeakers_TQWT - Tapered Quarter Wave Tube alias Voight pipe - fullrange speakers, horn, high efficiency, tqwt, multiple arrays, general audio topics>
thank you!
Old 9th May 2013, 11:59 PM   #64
TicoLizard is offline TicoLizard  Costa Rica
Hi Guys,
In post #5, GM is recommending a six inch in diameter port, 3/4 of an inch long? Like a six inch hole in 3/4 plywood? Sorry, this just seems large to me, so I wanted to double-check.
Thanks.
Old 10th May 2013, 02:08 AM   #65
Got Foam?
xrk971's Avatar
That is correct, a 6 inch hole in 3/4 inch baffle is the port. You can also do it with smaller dia and longer but that requires you to have an actual port tube.
Old 10th May 2013, 05:25 AM   #66
GM is offline GM  United States
GM's Avatar
Hmm, reducing the vent area [Av] will tune it lower, ditto making it longer, so for a given tuning, Av must increase if you want to lengthen it.
Since the MLTL is damping the vent enough to allow a large, efficient enough Av at only ~3/4" long, any additional damping due to a larger, longer vent would only be required if playing at high power for extended periods, so basically never in a HIFI/HT app. Worse, at least from a distortion POV is it can potentially 'color' the mids due to its pipe harmonics comb filtering with the driver's output as happens with many Onken alignments.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th May 2013, 04:15 PM   #67
Got Foam?
xrk971's Avatar
GM,
You are right, I got that backwards That is good to learn that for HiFi, a shorter vent is preferable for less coloration from pipe harmonics.
Old 15th January 2014, 03:51 AM   #68
golgiapparatus is offline golgiapparatus  United States
Question Any information on the Specks
Originally Posted by Gost22 View Post
Hi all!
See and enjoy!!
I like what is in the PDF is really beautiful, do you have any specks on the output, what is the F3? What does it sound like? Are you happy with what you have? Would you have added a tweeter? What did you do for the crossover?
Did you finish the project?
I just got 2 BG20's and want to build a TL, I have purchased the Mathcad software but have not had time to really learn how to use it.
Thanks,
Golgiapparatus
Old 23rd September 2014, 03:24 PM   #69
Buehgemeiste is offline Buehgemeiste
Hi everybody,
i like the Visaton BG20 and know its sound in both br- and horn-cabinets.
I found this thread by searching for tml-enclosures.
I wonder if any of the suggested cabs from this thread were built.
Maybe somebody has something similar to share for this driver?
Usually the BG20 needs some 'LCR-taming'.
How would that be in a tml/tqwt/similar design?
Old 23rd September 2014, 07:49 PM   #70
GM's Avatar
Assuming the specs are reasonably accurate, all the [ML] TL designs done with MathCad will be accurate, though keep in mind that all such programs are designed to be accurate only up to the driver's effective HF mass corner [2*Fs/effective Qts], so other than some HF harmonic rippling from the vent system the rest can be ignored.
Not familiar with the driver, but many wide range drivers need significant mids, HF response filter shaping including baffle step compensation [BSC] if not near/at a wall or corner.
GM
TL-box for BG20 VisatonHide this!Advertise here!
Pioneer B20 and Visaton BG20 inrank Full Range 28 11th July 2011 03:00 AM
Modify a Visaton BG20 heinz1964 Full Range 0 12th February 2008 09:06 PM
Best enclosure for Visaton BG20 zek Full Range 7 22nd July 2005 09:47 PM
What eclosure for Visaton BG20 zek Multi-Way 7 15th August 2003 05:28 AM
