Old 14th January 2013, 08:38 PM   #1
bocosb is offline bocosb  Romania
Default Bookshelves powered by T-amp for nearfield
Hello guys, i'm new to diy and i'm researching my first speakers so i would like some guidelines:
- I want to make a pair of bookshelves which will be placed on stands on either side of my desk. The listening position will be sitting at the desk (working on the pc).
- The amp will be a T-amp, somewhere around 10w/c (already have it), source asus xonar stx from pc.
- The room is small, around 12'x9' (3.7mx2.9m). The speakers will be close to the wall about 1 feet, and the listening position in the center of the room about 4 feet from the speakers. Will add a room plan for better understanding.
- I want something easy to listen for lots of hours in a row, i listen to all types of music but mainly vocals, acoustic, jazz, classic rock.
- Atm i have 2 way 6.5'' 'regular' bass reflex speakers, aprox. 16l volume, but i could go bigger if needed, no WAF problems in here, it's my man cave
I read many threads the last 2 days and i find Mark Audio drivers appealing(but not sure about the sensitivity paired with my T-amp).. do you think it would ok for my needs? Alpair 7, 10 or 12? Or try something cheaper for my first project?
Also the variety of enclosures is confusing what would work best in my situation? (nearfield)
Old 14th January 2013, 09:03 PM   #2
The reduced BSC version of this should be good :
Zaph|Audio - ZMV5 - MCM / Vifa 5" System
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 14th January 2013, 10:48 PM   #3
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
I have a pair of Mark Audio CHP-70's on my desk at work. I use an old Sony receiver to power them. It's right around 18 WPC. I'd say you would probably be OK for nearfield listening with your amp. I'm a fan of Mark Audio speakers, so I'd say build a set and if your amp isn't powerful enough, get a larger one. I know that sounds bass-ackwards, but for bang for the buck, in my opinion you can't do much better. Depending on your budget, you could even go with 2 or more drivers per cabinet. That would give you a few more dB.
Sorry to spin the post around, but you mentioned Mark Audio, so it got my attention.
Mike
Marantz PM8003 amp, Squeezebox Touch, DIY Krystals
Jolida SJ502B, Mark Audio Alpair 10.2s
Old 14th January 2013, 11:21 PM   #4
You could build a pair of uFonkens with some Fostex FF85WK drivers. These are small and very detailed but will not produce the bass of larger drivers.
Old 15th January 2013, 01:17 AM   #5
Bare is offline Bare  Canada
Uhh remembering that Sounds originate from the PC and likely internet downloads.
Even a Logitech 'puter monitor' setup would work 'jes fine'
Old 15th January 2013, 01:36 AM   #6
xrk971 is offline xrk971  United States
xrk971's Avatar
I listen to these all day long in a room about the same size as yours. Although made using some very inexpensive drivers the cabinet really makes it sound rich and full. They excel at vocals, acoustic stuff and jazz. They are wall mounts though, and from your picture it looks like you have wall space. They are indeed made using Logitech 'puter speakers You can build a slightly larger upgraded version with 3 in drivers that will be 16 in square.
Post 60 in this thread Ever think of building a Cornu Spiral horn? Now you can!
Here is a 16 in version made with TB w3-881si drivers Ever think of building a Cornu Spiral horn? Now you can!
Old 15th January 2013, 09:09 PM   #7
rgds, sreten.
That system looks like great value for the money and the reviews on the drivers seem very good but i want to try a fullrange speaker design. And i have zero experience with soldering so i try to avoid crossovers for now
The Asus Xonar Essence STX i'm using is pretty well regarded in terms of audio quality and my music is mainly ripped loseless format, so i would'n call that a problem, plus in the future i'm considering a dedicated DAC for the system
I really like the ideea of a "onken" cabinet but i would go with a bigger driver then the Fostex
Mike
I read about the CHP70, very well regarded but if budget will allow i think i'll try the Alpair 7.3 - it seems that lots of people are considering it one of the best fullrange speaker you can get.
That is a very interesting design, looks easy to build but for the moment i want to make a standmount. But in the future I definitely see myself building two of this pizza boxes
Some more questions: if i settle on a Alpair 7.3(or something similar), what would be the differences between the BR cabinet and the onken style?
And another thing.. i never heard a fullrange speaker. Making some calculations the build will get me to around 3-400$. That's the price range for good quality commercial entry level bookshelves. How is a full range diy speaker(let's say based on the above Alpair 7.3) compared to these speakers? I know the sound signature is different, but a rough quantification of sound quality will put my mind to ease(as in a confirmation for getting better bang for the buck)
Old 15th January 2013, 09:10 PM   #8
t-amp
a good starting point ;-) let me think a bit on it...
do you have a powered sub?
Old 15th January 2013, 09:19 PM   #9
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
I'd say start out with a 2-way, but only use 3dB of baffle step compensation. Most designs on the internet use 6dB, and this is unlistenable when your speakers are near the wall. Vocals get drowned out by the bass. Using the right amount of BSC is the most critical aspect to the final sound of the entire system.
The Alpair 10.2 has 3dB of BSC already built in, which makes it easy, but it's on the expensive side.
Old 15th January 2013, 09:21 PM   #10
interesting! yes, also seemed expensive to me...
so, do you need "real" fullrangers or do you also have/plan a powered sub?
fullrangers have kind of a special sound, well, you'll get to know it then... they don't necessarily have to be expensive... there are also some "cheap" ones that are really "good", imho
with pc as source, you can also use a software EQ for the BSC... as well as for some maybe needed notch filter(s)
Want to build Unusual high powered battery powered headphone amp (and equalizer) bakalorz Headphone Systems 5 10th September 2012 03:17 AM
Want to build budget nearfield computer speakers, which plans/amp to choose? mbayaq579 Multi-Way 18 3rd August 2012 09:03 AM
Need Nearfield amp recommendation argonrepublic Solid State 6 19th August 2011 04:48 PM
Need Nearfield amp recommendation argonrepublic Solid State 0 21st July 2011 11:14 PM
Unblowable Bookshelves? deadmau5 Multi-Way 11 18th April 2011 01:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
