FAST woofer choice for Alpair 7.3
Old 15th January 2013, 10:17 AM   #21
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
yes that one. Ive found it cheaper than europe audio, for what i was buying. Visaton AL200 may be worth a look, around your budget if i recall.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 15th January 2013, 10:44 AM   #22
Studio Au is offline Studio Au  United Kingdom
Should I consider any other products in the Alpair series?
I have the Alpair 7.3's, they are in a very pretty walnut box and working well.
As bass will be handled by a yet unknown woofer, is the Alp7 the best for mid-high, would the Alp10 perhaps offer a lower xo point, and better integration, or maybe a cheaper Alp6P with paper cone for a more natural sound?
Old 15th January 2013, 10:58 AM   #23
that i couldnt answer, other than with a guess. I have a pair of 1st gen A5 which are nice, and although i havent heard the others as small a mid-hf source is best. For me 3 inches is my limit, no bigger or hf suffers. Thats my take on it. Tuxedocivic has a fast thread, addressing some of the pitfalls.
Old 15th January 2013, 04:11 PM   #24
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
I wouldn't be concerned with how low you can cross. I'd go with a 3". Even a 3" can handle most 150hz cross overs without issue. And why not raise it up a little to 200hz. The change is only positive in my opinion.
I've been using this little cheapo in my FAST: Tang Band W3-881SI 3" Speaker 299-113
It's really good and can't take much power, but with the cross over set at 300hz I'm really pushing it and it has no issues. Every once in a while I can hear the treble get whiney cause of breakup or something, but it's really quite mild. Most 4"ers are only worse.
Old 16th January 2013, 05:20 PM   #25
Toaster is offline Toaster  United Kingdom
Regarding XLS vs SLS, the latter will have a wider usable response into the midrange than the former. This would give you more flexibility on where you crossover. OTOH, the XLS will handle more power, if you have it, and has the potential to go lower, louder. As you say, it will also build into quite a small box. Horses for courses. I should point out that I have no direct experience with the SLS series, but they seem well-regarded by those that have used them, including John K., which is good enough for me. I have used the Nomex-coned XLS 10" and 12" drivers and they are very good, well made units, but I wouldn't use them above about 200Hz from experience.
Old 3rd December 2013, 07:48 PM   #26
Been looking at having OB woofers, especially to mate with my Betsy's that are sat around.
Any reason not to try a Eminence Alpha 15a each side, running OB as a FAST, helper woofer?
FAST woofer choice for Alpair 7.3Hide this!Advertise here!
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Full Range 58 3rd November 2015 02:07 AM
Alpair 6p FAST Einric Full Range 4 3rd November 2012 02:53 AM
FAST build with an Alpair 7.3 and a 12" Peavy Pro 12 woofer golgiapparatus Full Range 6 2nd November 2012 12:07 PM
Alpair 7 FAST Prototype Westy37 Full Range 9 17th October 2011 08:48 AM
Woofer to use in a FAST with Alpair 5 (desktop system) Westy37 Multi-Way 5 31st March 2011 06:23 PM
