routing wire in BLH designs?
Old 11th January 2013, 06:26 PM   #1
jmroach is offline jmroach  United States
Default routing wire in BLH designs?
I'm currently building the Dallas III and just realized I have no idea how to route the connection to the speaker... It seems like this would be a common issue for BLH designs as they commonly lack a direct path to the back of the enclosure, but I can't seem to find any information on it...
It seems like the logical options are:
1) route to the side of the enclosure instead of the rear (but I don't like the look of this)
2) route through the passage and somehow caulk/glue along the way to keep from vibrating (would prevent 'rewiring' in the future)
3) slightly chamfer the corner of the pieces that makeup the passage and route 'over' the walls, caulk where wire passes over wall. (would prevent rewiring)
None of these options seem very good to me... What am I missing? This method sure doesn't appeal to me...
Thanks!
-john
Old 11th January 2013, 06:46 PM   #2
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
For the Cornu spiral BLH, we either put a recessed binding post cup directly in the driver chamber, or cut little holes in all the channel walls for a straight path for the wire and seal it with hot melt glue (or caulk if you like). You could route it through the tortuous passage but it would have to be glued down otherwise it could rattle, and it would obstruct the flow over a long distance. Whereas the perpendicular penetrations have a shorter interaction.
Old 11th January 2013, 06:52 PM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
For the dallas it is pretty straight shot right out the back once you drill a hole in the air cavity.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
routing wire in BLH designs?Hide this!Advertise here!
Are there any BLH designs for the Fostex FF225K's? Rick J. B. Full Range 10 4th May 2010 08:37 PM
PCB Routing Mark245 Parts 15 27th May 2009 07:54 PM
Routing advice Glen1 Subwoofers 14 24th May 2007 04:02 PM
Aleph wire routing question D97GT Pass Labs 2 22nd December 2006 07:32 PM
Routing the recess? xyrium Multi-Way 49 14th July 2005 01:54 AM
