maybe im crazy but...3" FAST system? - diyAudio
Old 11th January 2013, 05:41 PM   #1
mondogenerator's Avatar
Default maybe im crazy but...3" FAST system?
hi folks.
Im looking for 3" bass driver suggestions for a FAST build. It will likely feature W-W-Fr-W-W or d'appolito arrangement.
Driver sensitivity of the W may be the fly in the ointment, havent run any numbers as yet.
I have considered the NS3 but in unsure if theyre hifi enough to partner the A5 im likely to use as the FR component. Can anyone here help me out?
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 11th January 2013, 07:09 PM   #2
frugal-phile(tm)
planet10's Avatar
You get a lot more optionsif you move to a 4" woofer. We use the Peerless 830870 with the FF85 with great results. If you have to livewith a 3" then the Aura is one of the best FR of this size in the bass, there may be some small TBs purpose built that may be better.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th January 2013, 07:36 PM   #3
Default it was actually a discussion we had that inspired this.
A combination of my recent quick n dirty tests with the A5, and a conversation we had Re using 3 2"drivers in MTM. So I got to thinking, in my own way
Ive had the 1st gen A5 sat around for aeons and Im still a little unhappy with any design Ive come up with, so far.
Ive put an A5 in a 3" tube, and stuffed til i cut the combing acceptably. Using GEQ ive notched out the peak on the A5. Not ideal but after a few nights listening im happy. Using the 2nd order HP built in Ive set at 40hz. Next i added some EQ to try and offset the awful BSC that I need, given the driver is bunged in the end of sonotube. I should do a impedance curve...
Anyway, I have no idea where Fc is in this tube. Now I understand the A5 isnt really designed for bass but to Ive been surprised how much bass I hear, and how much bass EQ I managed to use at volumes Im happy with for TV and some films. (i said something similar recently in another thread so I shouldnt go on)
Getting off the point. Apologies. Anyway my room is small, and I sit ~2m away. My voltage input for Panos's thread some time ago revealed I probably listen at 88dB max (unless its a party).
So the next thought was an MTM or MMTMM with 3 or 5 A5s instead (assuming theyre sold still) maybe a 'double BSC' in the MMTMM with the two outer pairs (maybe really crazy)
Then I thought of the Aurasound instead. Then I thought 'no' a set of 5 panpipes with A5s in somehow seems a great idea. (maybe only to me... But this is since I think Im getting a solid 40-50 Hz out of these, then just an MTM would give me sufficient headroom, perhaps even an MTM would suffice.
So 'other' options are welcome, as with a single A5 im near Xmax at my typical levels and EQ.
Old 11th January 2013, 07:59 PM   #4
frugal-phile(tm)
planet10's Avatar
Not for a long time. New Euro laws regarding ferrofluid makes them impractical.
dave
Old 11th January 2013, 08:04 PM   #5
Default I also noticed your own 'tubes' only you had the good sense to use PVC pipe instead..
Ahhhhhhh!
I didn't realise they were ferrofluid drivers...........
Thanks. I'm not really aware how that effects us in the UK to be honest, OR how long the ferrofluid in a driver of this type will survive given the higher excursions.
But something cheaper would be better if its going to last. Id imagine the already high Qts (or Qes) would skyrocket once the ferrofluid dries out.
Just checked and youre right
Thanks (curses
Guess Ill have to look at what I can do with the Aura or something larger.
I should really just measure the impedance and try to work out whats happening in my room with these A5. I feel like I should know and then Id have something useful to write
Henkjans desktop TL is appealing, but the A5 isnt so good in it (I think thats correct, and I think my TB W3-1285sg would work better) It could be that I have a similar length path, and the EQ is helping things. CSA is the big difference.
I need to do testing and less typing most likely. I test all day, study at night, DIYA on the train....crazy
Cheers for the direction
Old 11th January 2013, 08:37 PM   #6
Scottmoose's Avatar
3in bass driver = oxymoron. HD is usually crippling; if you run them sans highpass IMO you're generally best with sealed or some form of aperiodic. Just my take on it of course, & I'm occasionally a hypocrite when the mood strikes.
Old 11th January 2013, 08:38 PM   #7
frugal-phile(tm)
planet10's Avatar
It is not as if the ferrofluid dries up. If you play the drivers too loud you can slowly expel some of it.
That has nothing to do with them dissappearing.
If you are going looking keep in mind that the Jordan J6T is essentially the same driver (different lead-outs). Bob at CSS might have some, i'm pretty sure has a paitr he'd free in the interest of your prokect.
But myself, i'd use something more capable. Even NS3 is a big step up... 4 of them would give ~88 dB,
dave
Old 11th January 2013, 08:53 PM   #8
Yes you're Both probably right!
Yes HD goes up. Its just that with the A5s I find I dont notice a major change in THD (or rather the onset) with at louder levels, nearer Xmax.
In other 3" theyre excursion is limited (i.e. the W3-1285sg).
I thought it was clean and to be totally clear, It Is within its Xmax and a tiny bit beyond, but the onset of THD is gradual and at similar excursions to the A5 (xmax is only 0.4mm) it is perceptable. annoying since Xmech must be about 4mm p-p
the down side to that is that they (W3-1285sg) probably also would like to be high passed, but certainly more that because occasionally instead of any compression, you get THD on VLF dvd audio content with just touches the peaks of audible content.
Thanks Dave, Im not looking per se, more like it was just the beer after work at the end of a week that is responsible. To be honest I didnt think I could notch the peak out of the A5 well enough and surprised myself by getting it 90% there. Now ive got around to doing it, the A5s I wasnt so keen on at first, are now defunct
To be honest at TV levels and especially on TV I like the way they sound running full range now, and with the EQ, even better.
Last edited by mondogenerator; 11th January 2013 at 09:04 PM. Reason: SOrry im an edit-o-phile
Old 11th January 2013, 09:32 PM   #9
Default Audio Virus?
Well Ive literally just stumbled across these Audiovirus BPP things.
I thought the TS looked similar to the A5 so I just checked in Win ISD:
xmax of 4mm.
hmmmmmm
Old 13th January 2013, 09:44 AM   #10
Default My Z plot of the A5 in the tube, for those who are interested.
Here is a plot of Z ive just taken with the A5 setup as previous (of course EQ is bypassed):
'Reflex' double peaks appear at ~40 and ~120 Hz, with the associated dip at just under 60 Hz
The next Dip is at ~ 200 Hz
The higher Z peak appears at around 250 Hz
Dip to dip (60 & 200Hz) appears close to 3rd harmonic at 180 hz
Anyone have any comments (can you spot any glaring errors in my assumptions?)
BTW in post #8 I meant 'my reasons for being less keen on the A5 are defunct', not the driver
Thanks for reading.
Greg
looking for effecient 4" driver for FAST system Josephjcole Full Range 24 13th April 2011 12:50 PM
FAST system in a vehicle 901Fixer Car Audio 0 26th November 2010 07:56 PM
Crazy/cool horn system compaddict Multi-Way 7 17th April 2009 02:34 AM
FAST System hm Full Range 9 25th May 2007 07:06 AM
Yes im crazy.*horns involved* mikee12345 Multi-Way 32 12th November 2004 12:10 AM
Copyright 1999-2017 diyAudio
