FH3-inspired Foam Core Mini Build
Old 16th March 2013, 09:16 PM   #61
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Even if you add in the cost of the Cornu project to the $24 for the Vifas and $6 for the foam core here, the mini-FH3 is still a great bargain. And a bunch of fun as well!
Agreed. One of the best sounds around for $30/pair, and a lot of fun.
Old 24th March 2013, 04:46 PM   #62
Got Foam?
xrk971's Avatar
More sound clips of this speaker teamed with a foam core class D amplifier here:
http://www.diyaudio.com/forums/class...ml#post3425164
Old 24th March 2013, 04:58 PM   #63
KLBIrd is offline KLBIrd  United States
KLBIrd's Avatar
I can't seem to open the audio clips. Windows say they are not compatible. Any clues for me.
Old 24th March 2013, 05:21 PM   #64
Got Foam?
xrk971's Avatar
Rename the extension to .rar (type of archive)
Sorry
Old 24th March 2013, 06:04 PM   #65
Got Foam?
xrk971's Avatar
Sorry about the mixup. Here are the files re-uploaded as true zip files. They have been tested to work this time.
http://www.diyaudio.com/forums/class...ml#post3425347
Old 17th November 2013, 02:28 AM   #66
tb46 is offline tb46  United States
Default FH3 Inspired Bipole (?)
Hi xrk971,
Have you tried your FH3 inspired layout as a bipole? Looks almost like a natural for that.
Oliver
Old 17th November 2013, 03:32 AM   #67
Got Foam?
xrk971's Avatar
No bipole yet, but maybe one day... It is not as simple as cutting a hole in the back - the volume has to be doubled along with the vent CSA. So it would be a complete rebuild. My attention is more on a Synergy or a Karlson type speaker lately.
Old 17th November 2013, 05:52 PM   #68
Hi xrk971,
I have seen your first try at a Synergy/Unity horn. Someone posted a link that has a lot of good information as to the location of the speaker entry holes, etc. Good luck with that one, a very interesting design.
I still think a bipole FH3-Inspired would be interesting.
Oliver
Old 1st February 2014, 10:29 PM   #69
prezden is offline prezden  Canada
I finally got around to building a pair of FH3 Foam Core Mini using Aura ns3-193-8a1 drivers that I had on hand. I basically used the dimensions That X provided a year ago with one modification is that I changed the back of the flared sides to 10" instead of 12.
The build didn't go as well as it should have; they aren't square- more a parallelogram .
I only had enough felt to cove the back panel and used poly stuffing around the driver.
Sound is fairly good the mid and upper range is very good but lacking a bit in the bass. I'm still messing around with the stuffing as you can see in photo 3.
This is a good fun project- Thanks X for getting this one started
cheers
Old 1st February 2014, 10:44 PM   #70
Got Foam?
xrk971's Avatar
Prezden,
That looks great with the stained plywood! Congrats on another build. You were going to build a Met that I sim'd for you at some point or did that morph into the 24 in Cornu? The stuffing makes a huge difference - very light amount below driver - loosely pulled out and just an inch or two.
FH3-inspired Foam Core Mini BuildHide this!Advertise here!
Foam Core Board Speaker Enclosures? xrk971 Full Range 2944 Yesterday 07:52 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
Build ADC for Core Audio hugofurther Construction Tips 1 11th November 2012 11:14 PM
Looking for source of mini trans. core dayveshome Parts 1 23rd February 2012 01:40 PM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
