FH3-inspired Foam Core Mini Build - Page 4 - diyAudio
Old 27th January 2013, 12:15 PM   #31
KLBIrd is offline KLBIrd  United States
KLBIrd's Avatar
Send a message via Skype™ to KLBIrd
I've used foam insulation board for mock ups (Audio Express, 9- 2011 issue.) but never tried it in a live enclosure. Foam enclosures would save money and reduce dust in the shop. You could use 1/2 inch wood strips as corner blocks to reduce resonance. I'm going to get a few sheets and give it a try.
Old 27th January 2013, 12:27 PM   #32
xrk971 is online now xrk971  United States
xrk971's Avatar
That is my biggest advantage in using foam core is no dust as I currently do not have a shop so all speaker builds are indoors in the kitchen or rec room. No power tools needed either - just a razor. Are you considering the foam core FH3-inspired speaker or something else? A folded MLTL, a TABAQ for example, is a great way to get started that sounds really nice and is simple to make.
Old 27th January 2013, 11:35 PM   #33
KLBIrd's Avatar
I am thinking about a quarter wave with a Dayton ND 105 4 inch driver.I also have couple of the Audience 3 inch drivers they use intheir line array system. I want to experiment with the 1/2" Johns Mansville insulation foam board I used on my mock up on the Castle Speakers. Its denser than the smaller craft board, yet still ultra light weight compared with MFD or plywood. Can be glued with craft glue or the special caulking they make for installing it.
Old 3rd March 2013, 01:11 AM   #34
xrk971's Avatar
I am thinking of trying this design at a larger scale with a 4 inch budget driver. The Visaton FR10 that Ken turned me onto looks very promising for a larger design, I am actually thinking of going with the 4 ohm variant to get more power from my T-amp delivered to the driver, The driver is $12 at MCM Visaton 4 Inch 20W 4 Ohm Full Range Dual Cone Speaker | FR10 2020 | Visaton
http://www.visaton.com/en/industrie/...nd/fr10_4.html
Specs:
Rated power 30 W
Maximum power 50 W
Nominal impedance Z 4 Ohm
Frequency response 80–20000 Hz
Mean sound pressure level 86 dB (1 W/1 m)
+/−4 mm Excursion limit
Resonance frequency fs 92 Hz
D.C. resistance Rdc 3,2 Ohm
Mechanical Q factor Qms 2,29
Electrical Q factor Qes 0,7
0,54 Total Q factor Qts
Equivalent volume Vas 2,3 l
Effective piston area Sd 50 cm²
Dynamically moved mass Mms 5,7 g
Force factor Bxl 4,6 T m
Inductance of the voice coil L 0,2 m
Note that the specs of this driver is very close to the MA CHR70: except for Vas
Old 10th March 2013, 09:31 PM   #35
Jim Shearer's Avatar
I have begun building the FH3 inspired foam core speakers to give the Vifa TC9FD a try. Just for fun I ran a simulation in MJK's MathCAD worksheets. Modeled as an MLTL (similar to a Metronome, just folded and with a rear firing port instead of down firing).
The stuffing/lining should improve the suck-out in the 400-500 Hz (I hope).
Cheers, Jim
A day without music is like a day without food.
Old 10th March 2013, 09:47 PM   #36
xrk971's Avatar
Jim,
Thanks for doing the sim on MJK. Did you use the dimensions I have on post 28? How did you handle the rear horn? My measurements actually go down a little lower than 80 Hz. Looking forward to your build. I think KenLBird said he will be building it too.
X
Old 10th March 2013, 10:03 PM   #37
Hi xrk,
I used your dimensions for the enclosure minus the 'horn' behind the port. The MLTL worksheet has no provision for dealing with that. (I also didn't bother with the later parts of the worksheet where you enter further details of the enclosure, etc.)
To better simulate, you would have to use the BLH-sections worksheet; being lazy, I didn't bother going there, as it would mean learning how to deal with that sheet. Maybe someday.... or maybe not...
BTW: I am simplifying your design by making the 'horn' behind the port a straight (as opposed to curved) expansion. Yea, lazy, lazy, lazy.
Cheers, Jim
Old 10th March 2013, 10:19 PM   #38
xrk971's Avatar
Jim,
The curved sides are easy and their difficulty to execute shouldn't be over-estimated. It takes 15 minutes to score the lines on the side to allow curving before you glue it on. Make the base curved with the flare out. You have built cornu before so know how easy it is to bend, hold, tack with hot melt and you are done. It looks and sounds better with curve - gives you 3x gain on horn expansion and adds stability to base. Trust me on this
One other thing, since you have benefit of sim, try reducing terminus gap from 1.33 in to something a tad smaller. It should pull bass extension down lower if that is what you want.
Old 11th March 2013, 02:00 AM   #39
xrk971's Avatar
Cheers, Jim
Jim,
It's actually kind of surprising how good the sim is given the crude scaling I did which shouldn't have worked given the feedback I got on how nothing depends on Sd. Lucky
I guess? If you can do me a favor and run the sim with the params for the FR10 driver I have above - keep dims the same. I am wondering what a swap would do.
Thanks,
X
Old 11th March 2013, 03:43 PM   #40
Originally Posted by xrk971 View Post
Jim,
Thanks,
X
Guess you got lucky. And the reason I decided to proceed.
Using your original dimensions, the FR10 doesn't look nearly as nice. An expert like Scottmoose could probably adjust it in a jiffy to get a good alignment. I expect I would need to fiddle for two or three weeks to fix it.
Cheers, Jim
Foam Core Board Speaker Enclosures? xrk971 Full Range 2817 14th September 2016 03:13 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
Build ADC for Core Audio hugofurther Construction Tips 1 11th November 2012 10:14 PM
Looking for source of mini trans. core dayveshome Parts 1 23rd February 2012 12:40 PM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
