Hi all,
I'm in the process of building my first set of BLHs (first full-range for that matter). I have selected the Dallas III and have read that no plans for this speaker exist, but that others have just "smoothed" the Dallas II. That's what I'm doing as well. Here's the issue I've run into: in the only plans I could find, no dimensions I would think to be critical are listed! What I'm referring to mainly are the passage heights at various positions (ie. between the start & end of pieces 2 & 4, 7 & 12, 12 & 15). Does anyone have this data? All I can think of is comparing these to other dimensions on the print or performing some serious geometry shenanigans? Thanks in advance! -john |
#2 |
#3 | |
#4 |
frugal-phile(tm)
Given that that is a snapshot of one ofmy drawings, i will have CAD files if that is helpful -- obviously not finished to my liking or they would be posted on FH.com
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
As a more general note-- Do you have a sense for how sensitive the design is (or other BLH designs are) to geometric deviations? For example, would one of the passages entrances/exits being too big/small by 1/16" affect the performance? 1/8"? Thanks! |
#6 |
Thought I would share a few more pictures of the progress. I didn't really find any in-progress pictures of this design before i started. Hopefully these will be useful for someone else who decides to tackle the same project.
Here's a short rundown of the construction: it's 1/8" bending plywood sandwiched on both sides of 5/8" marine-grade plywood. It helps a lot to get the bending plywood damp before trying to manipulate too much. Glue is titebond #1. I tried cutting dados in the 5/8" plywood to accommodate the bending, but it didn't provide enough compliance. Corners are 1/2" to 1" strips depending on the radius of curvature. note that the divider is "floating" in the last picture. |
| Dallas III plans? | wixy | Full Range | 5 | 6th April 2013 04:54 PM |
| Dallas III | wat44 | Full Range | 7 | 27th January 2010 11:30 PM |
| DIY Back Loaded Horn - Dallas III for Fostex 206E | jasonlky | Full Range | 46 | 6th April 2008 11:50 PM |
| Where is the Dallas II | amisdad | Full Range | 16 | 5th November 2005 04:57 PM |
