small sealed monitor
Old 9th January 2013, 06:31 AM   #1
audiothings is offline audiothings  India
Default small sealed monitor
I am building a studio for a friend. We have our main monitors and nearfield monitors sorted out.
for my third monitoring source, i want a pair of small sealed, full range drivers. i do not want bass below about 100 Hz... this speaker will be used to monitor the critical mid range only - and also to make sure that there is enough bass guitar and kick drum content in the mid ranges, for the music to sound sufficiently full when played back through small speakers.
(currently I have a Fostex Fx120 performing similar duties in my studio.)
the auratone 5c is a classic studio monitor used for the same purposes.
NOW.
I want to put these Alpair 7s into a sealed box of approximately 5 liters. Will they serve my purpose? Will I need BSC or any other circuitry?
Is it $85 for the pair or per piece?
Thanks.
Old 9th January 2013, 07:01 AM   #2
chrisb is offline chrisb
great driver, but 5 liters sealed is possibly too small? - even if not they'd probably breathe easier and more readily display the dynamics, imaging detail and other parameters of the mixing work you're trying to monitor, in a vented design - of which numerous examples can be found on either this manufacturer's forum, or the larger Full Range section
each
kinda burnt out - taking a break
Old 9th January 2013, 07:13 AM   #3
thanks chrisb. i can go up to 8.
anyway, at $85 a piece, they are out of my range... it says "drivers are packed in pairs" - and so i thought I could afford it...
Old 9th January 2013, 08:29 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
5 litres would be fine.
small sealed monitor-a7g3-sealed-gif
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th January 2013, 05:22 PM   #5
Yes, that could be a bit confusing, and inconvenient for those looking for an odd number of drivers, as in for a 5 or 7.1 HT surround system
How about the Fostex FF105WK?
small sealed monitorHide this!Advertise here!
7" woofer for 2 way sealed monitor audiothings Multi-Way 34 16th January 2011 08:42 PM
Small sealed subwoofer Francesco Subwoofers 1 15th September 2009 02:38 AM
small sealed 8" oogared Car Audio 8 11th July 2006 08:39 PM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 09:50 AM
how small of a sealed box could i get away with ? zuki Multi-Way 6 25th August 2004 09:12 AM
