diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Desktop Full Range Project (http://www.diyaudio.com/forums/full-range/227320-desktop-range-project.html)
Millicent Bystander 8th January 2013 04:16 PM
Guys
Due to their shallow depth I'm considering building a pair of these for near field desktop use.
Now these look to employ a pair of Tang Band W4-1320SIF. But for the life of me I can't find out the manufacturers recommended enclosure volume. Can anyone help me with this? Also, should they be ported or sealed?
Also, as a design challenge I was considering concrete as a material, or 19mm ply sandwiched together. Anyone care to comment on the material choice?
Now I've considered the mHonkens and have built three of Dave's designs which I love. This time I'm looking for something visually different for my computer speakers. More of a design statement, but with solid audio performance.
Thoughts?
Elliott
planet10 8th January 2013 06:47 PM
Interesting speakers.
I don't see much point in using anything beyond PVC pipe, or even thick cardboard tube for a speaker like this.
My 1st inclination would have the driver in the "box" you point to as a 3"/
I have a similar speaker that uses a standard PVC adapter with a fitted wooden ring with 4" PVC pipe that perfectly fits both an Alpair 5 and the big buck 3" Scan Speak 10F (only 2 drivers i have tried in it.
http://www.diyaudio.com/forums/attac...pipes-comp.jpg
dae
Millicent Bystander 8th January 2013 07:58 PM
Thanks Dave.
I see the volume of your tube speaker are significantly larger than that of the "Well Rounded" design. Part of their appeal to me was their shallow depth. In that they would sit either side of my laptop without taking too much space.
What drivers do you think would suit such a small enclosure?
Is concrete generally frowned upon for small speakers like this?
chrisb 8th January 2013 08:32 PM
Originally Posted by Millicent Bystander (http://www.diyaudio.com/forums/full-range/227320-desktop-range-project-post3316852.html#post3316852)
Thanks Dave.
without hearing the Well Rounded, it'd be hard to say if the drivers used therein are achieving anywhere near their full potential - those are pretty teeny enclosures for sure
While a friendly debate could ensue if addressing the technical merits (or not) of using concrete or any high mass material for moveable speaker enclosures of any design (can you read between the lines on my thoughts on the subject? ;)), it's probably easier for most DIY hacks to make a decent looking enclosure folks from more conventional materials (wood, PVC pipe* / cardboard tubes, etc) than with concrete / diamond cored basalt - you name it.
So more than anything, I'd say it's the pain in the but-tocks factor that keeps more folks from trying it.
* see this old link to projects using off the shelf PVC / ABS plumbing pipe & parts
Laying Pipe with Audio Lego
As of the hour of this post, the links to thumbnail photos on the index page aren't working, but click on any of the individual project links for further details.
planet10 8th January 2013 08:53 PM
Originally Posted by chrisb (http://www.diyaudio.com/forums/full-range/227320-desktop-range-project-post3316910.html#post3316910)
Fixed.
dave
planet10 8th January 2013 08:57 PM
Thanks Dave.
My cab is just an example, in this case a mid-TL, if i was using it FR i'd optimize the volume for sealed ot Vented box.
Alpair 6.2 (either) or FF85wk would be my 1st choice. Your pipe would need 2.5 litre. The 6M and FF85 can get away with less volume (down to say 1.5 litre -- in the case of the 6M the vent becomes so large that you might as well build the 2.5.
dave
Millicent Bystander 8th January 2013 09:10 PM
I get the feeling they might be more "form" over "function" according to this review.
Oh well back to the drawing board.
tuxedocivic 8th January 2013 09:22 PM
On a desk, I'd go sealed and eq up the bass using the computer as a source. If the computer isn't the source, maybe ported then.
Millicent Bystander 9th January 2013 03:50 PM
Dave
Hypothetically speaking, what would I need to do to make your mHonkens "active" like the Audioengine 2?
Is there a suitable "off the shelf" plate amp that would be small enough (both physically and in power) to fit. Removing the footprint of a desktop amp would make these very appealing.
xrk971 9th January 2013 04:20 PM
Audio Engine has 15 w rms. The following amps are rated higher but when operated at 15 w rms, will have pretty good low distortion values. You can power them with cheap 19 V laptop bricks.
Stick one of these in each cabinet: Kemo M034N 40 Watt Universal Mono Amplifier Module 320-554
Or one of these in one cabinet and connect two boxes with speaker cable: 2x25W @ 4 Ohm TDA7492 Class-D Audio Amplifier Board Only 320-332
Or if you had a two way you can even bi-amp with this: 4x100W @ 4 Ohm TK2050 Class-T Digital Audio Amplifier Board 320-302
Resources saved on this page: MySQL 18.75%
