Two questions, please:
1.Tang Band's W5-1611SA Driver has been replaced with the W5-1611SAF. Has anyone any experience with both or can recommend that I replace the older with newer? 2. Fostex's FE138ES-R has been discontinued. Is there a viable replacement for it? Any and all comments, suggestions and opinions will be appreciated... MTIA |
#2 |
1/ The saf has largely replaced the sa simply due to the increases in cost of neodymium. Performance should otherwise be extremely similar. Neodymium was popular for a few years, in the majority of cases for its marketing value rather than any actual performance gain.
2/ No. Not from Fostex anyway. That was the only driver of those dimensions they ever produced. It was a special edition unit they struggled to sell. Partly because it was an unusual size for a Fostex, and most of their Japanese buyers, who the drivers are pitched at, are quite conservative over such matters, and partly because it was rubbish. |
#3 |
frugal-phile(tm)
FE138 had lots of promise but did not deliver. Fantastic bass, but it took the Fostex shout and turned it into a screech so was useless as a FR and expensive for a bass driver.
dave I have a pair of the older neo for sale.
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Many thanks to both Scottmoose & Planet10.
Concerns about the FE138ES-R are resolved... Merci beau. |
#5 | ||
Indeed, hard to believe that the same engineering team (or perhaps it wasn't? ) who brought you the F120 and 200A, FE166ESR and others could miss the target so widely. Some of the (combination of ) materials, surround and cone profiles etc employed in this designed have been used with great success in models ranging from the FF85K, to the full Sigma line
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| Disk capacitor replacement/upgrade | Nounours18200 | Power Supplies | 4 | 1st May 2012 12:07 AM |
| 2SA1102 and 2SC2577 Upgrade / Replacement | chipinnc | Solid State | 4 | 17th December 2011 01:18 PM |
| Transistor replacement/upgrade help | texaslonghorn | Parts | 0 | 11th November 2009 09:35 PM |
| cap replacement, upgrade | ineedahobby | Parts | 1 | 10th June 2009 03:03 AM |
| Cost Effective Upgrade Replacement For AD817? | fastcat95 | Solid State | 3 | 8th August 2003 06:58 PM |
