MJK's Fostex FF125wk BLH project
Old 16th June 2013, 07:52 AM   #121
chazdrumzalot is offline chazdrumzalot  United States
I'll try and get a horn measurement tomorrow.
Then again, what do I know?
Old 16th June 2013, 04:45 PM   #122
Here is the measurement, taken about 2" outside the horn mouth.
Old 16th June 2013, 10:55 PM   #123
A couple of pictures. Sadly, I think I probably damaged one W5's voice coil with a particularly violent 40hz test tone...
Old 17th June 2013, 10:10 PM   #124
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
I am sorry to hear about the driver. Have you measured near field driver output both with the horn running and then with the final sections filled with damping material to spoil the horn. The difference will indicate how much radiation resistance and at what range the horn contribute.
Old 18th June 2013, 03:11 PM   #125
Colin is offline Colin  United Kingdom
Originally Posted by Bob Brines View Post
This is interesting. I am corresponding with another European who was mentioning 6mm plasterboard. Is this a common construction practice? I believe that my 35yr old house has 1/2" drywall on 16" center 2x4's. I think that this is still standard practice. 5/8" drywall is also commonly available.
Bob
Plasterboard is common in modern UK houses, used as stud and partition walls between rooms, particularly in timber frame buildings.
MJK's Fostex FF125wk BLH projectHide this!Advertise here!
taming harshness of fostex FF125WK hajj Full Range 137 17th October 2016 02:32 PM
Disadvantage for place the Fostex 168e sigma into Fostex 166e BLH enclosure ? davidshya Full Range 2 27th January 2013 09:41 PM
Fostex ff125wk drivers and amps and more for sale? cross reference Swap Meet 0 15th December 2012 08:31 PM
Mileva Build Using Fostex FF125WK Drivers tomlang Full Range 7 21st November 2012 03:52 AM
fostex ff125wk vs markaudio alpair 7.3 (or10.2) castorG Full Range 4 20th October 2012 07:12 PM
