Alpair 7.3 vs 6.2m nearfield
Old 8th January 2013, 06:31 AM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Ive not heard the A6 latest version, but I have been messing with the 'old' A5 for a while now.
In a little cardboard tack and tape 5 minute experiment i found that the A5 used at loud desktop levels and with bass EQ makes a shockingly good pc setup. Now they wont shake the room but a clean rendition of bass down to 50hz is entirely possible with the caveat that levels would be limited. I used a rumble filter set at 40hz and rough approximation of LR transform from 100hz down to 40hz. I listen to mostly metal and i see no reason why the A6.2 M or P couldnt work.
At 1m distance and sitting at a desk, ~85 to 88db is plenty for me.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 8th January 2013, 12:28 PM   #12
xyz25 is offline xyz25  Germany
I found out that there is "spectrumaudio" just a few kilometers away from where I live - just emailed him if I could listen to some MA drivers, hope that works out
Old 8th January 2013, 04:05 PM   #13
The A5 gen1 that i have needed a notch with the GEQ to tame it, the newer A6 are smoother from others opinions.
Mine are loaded in a 75mm sonotube 1m long and a little stuffed. Aimed roughly horizontal a bit like a RPG...
bass EQ of 8db at 31hz, 4db at 63hz, and 0db at 125hz.
Maybe im hearing a strange dipole effect or a room mode but the bass output is surprising considering the lash up, and driver just stuck into the end of a tube.
Old 8th January 2013, 04:08 PM   #14
zman01 is offline zman01  Bangladesh
Man, that's loud
Old 8th January 2013, 05:20 PM   #15
Originally Posted by zman01 View Post
Man, that's loud
perhaps it was less than 88db even i measured with SPL meter phone app, so it could be ballpark figure. Not loud no. PC speakers they are not, but they make fantastic ones none the less.
Alpair 7.3 vs 6.2m nearfieldHide this!Advertise here!
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Full Range 58 3rd November 2015 03:07 AM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Full Range 11 8th January 2013 04:37 PM
Alpair 6p vs 6m vs 7.3 for a budget nearfield setup limyang Full Range 20 28th November 2012 10:25 PM
Small floorstander for Alpair 6.2M dimkasta Full Range 3 27th November 2012 09:25 PM
alpair 10 nearfield? need advice human.bin Full Range 7 11th February 2010 10:42 PM
