4x Series-Parallel vs 1x - diyAudio
Old 7th January 2013, 01:13 AM   #1
Question 4x Series-Parallel vs 1x
Given 4 identical small full range drivers, what is the difference between using just one or using all 4 in a series-parallel or parallel-series set? The obvious confounding factor is that the solo driver is a solo source while the 4x set is not. So, the 4 drivers could be mounted in a single enclosure or 4 single enclosures. In either case, they could be arrayed linearly or polygonally in a plane or in a 3D configuration. What would the benefits and drawbacks of the 4x set be? My little mind is overwhelmed...
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 20th February 2014 12:16 AM
OPC’s The WIRE – Latest Generation - PCBs for sale (4x BAL-SE, 1x SE-SE, 1x PSU KIT) fualcr Swap Meet 0 16th February 2012 12:39 AM
Series or Parallel / Bridge or Parallel? Tenson Chip Amps 2 3rd October 2011 01:53 AM
winISD calcs: parallel vs series-parallel sadams Multi-Way 1 20th February 2011 08:45 PM
FS: 1x Peerless 830860, 1x Vifa D25ASG-05-06 both unused chevy66 Swap Meet 0 12th May 2009 01:00 PM
Copyright ©1999-2017 diyAudio
