TB W3-881SI, which cabinet?
Old 6th January 2013, 12:42 PM   #21
gychang is offline gychang  United States
Originally Posted by Scottmoose View Post
Spot on.
I should stress, this box is not a bass monster (these things are relative of course -we're talking about 3in wideband drivers) -I wasn't aiming for maximum extension, but to provide something closer to a TL in terms of the load presented. If used near a front wall, you should get a reasonably balanced response down to about 80Hz since it does provide some modest broadband gain.
thanks for your help. I may have to experiment with damping materials, I have some polyfil etc... I understand bass is limited due to size.
gychang
Good sound from Davis, CA
Old 24th August 2014, 10:05 PM   #22
Originally Posted by Bjohannesen View Post
This one works very well !
http://www.coolcat.dk/bjoern/TABAQ%2...et%20build.pdf
Hi from
Bjorn
Bjorn: do I use the same BSC values for W3-881S?
Old 25th August 2014, 04:38 AM   #23
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Neat looking design.
Old 25th August 2014, 05:13 AM   #24
lcsaszar is offline lcsaszar  Hungary
A close relative of your driver, W3-871S works wonderful in a Buschhorn (2/3 of the original size that was intended for Fostex FE103E, I belive). I used 1/2" plywood.
Old 25th August 2014, 07:36 PM   #25
I am having trouble locating dimensions etc...
Old 26th August 2014, 04:50 AM   #26
Lautsprecher Buschhorn Mk II ein Basshorn fr 8er/10er Fostex Breitband-Speaker
TB W3-881SI, which cabinet?Hide this!Advertise here!
"nanoTower" - Tang Band W3-881SI cogitech Full Range 142 8th September 2014 10:20 PM
W3-881SI tabaq kenrhodes Full Range 13 28th September 2013 11:31 PM
Tang Band W3-881SI Line Array Help kctess5 Full Range 16 8th December 2011 10:25 PM
Help with TB w3-1053sc 2500hd Full Range 4 29th May 2010 03:12 PM
Tb W3-593sf sdclc126 Multi-Way 4 19th September 2007 03:14 PM
