TB W3-881SI, which cabinet?
Old 5th January 2013, 02:30 AM   #11
xrk971 is online now xrk971  United States
xrk971's Avatar
I think the folded Tabaq is pretty compact. Also, this driver has been used in the cornu with success (by Fenris). It is a pretty versatile driver for many types of enclosures. Just have to choose design.
Old 5th January 2013, 03:56 AM   #12
opa1 is offline opa1  United States
opa1's Avatar
I found the folded plans for the Tabaq.
MK
http://www.coolcat.dk/bjoern/TABAQ%2...et%20build.pdf
Old 5th January 2013, 09:25 AM   #13
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Originally Posted by gychang View Post
1/2" thickness plywood?, experimentation with old shag carpet leftover as damping material sound reasonable? what is the total depth of the cabinet?
smallish size is attractive for my small room.
gychang
1/2in is fine. I wouldn't be inclined to try carpet, it's almost certain to overdamp.
Old 5th January 2013, 11:32 AM   #14
Scottmoose's Avatar
Originally Posted by opa1 View Post
What are the labyrinth walls lenght? 2" from end? Port =2"x4"?
Apologies for not making it clearer. Each part of the labyrinth to the rear, behind the 5in deep front part where the driver is located, is 2in deep. The box is internally 10in tall, ergo, 10 - 2 = 8in for the internal baffle lengths.
Old 5th January 2013, 12:57 PM   #15
gychang is offline gychang  United States
what is the total depth?, see attached, also put the speaker in....
gychang
Good sound from Davis, CA
Old 5th January 2013, 01:12 PM   #16
Scottmoose's Avatar
5 + 2 + 2 = 9. For total internal depth you will, with the dark inevitability of Greek tragedy, add to that the thickness of the 2 internal baffles that form the labyrinth.
For total external depth you will add to that the thickness of the front and rear baffles. So assuming 1/2in build material is used, you would end up with a total external depth of 11in. With 3/4in build material, it would be 12in. With 1in material it would be 13in. And so on and so forth. The total length of the labyrinth will alter fractionally, but the drivers will exhibit more deviation than that, so I wouldn't worry about it. This box is about providing mild broadband gain & a well controlled impedance load so it's inherently more tolerant of minor deviations than designs with a more tightly defined / narrowly tuned alignment.
Old 5th January 2013, 10:22 PM   #17
So assuming 1/2in build material is used, you would end up with a total external depth of 11in. This box is about providing mild broadband gain & a well controlled impedance load so it's inherently more tolerant of minor deviations than designs with a more tightly defined / narrowly tuned alignment.
thanks for the info. Does this look about right?, will be using 1/2" plywood.
gychang
Old 5th January 2013, 10:24 PM   #18
Scottmoose's Avatar
No problem. Dimensions look fine, but you've put the driver directly above the terminus, at the end of the labyrinth, instead of in the main driver chamber at the beginning, where it's supposed to be.
Old 5th January 2013, 11:15 PM   #19
eeek!, I don't like to think when I am into my hobby..., any mistakes on this one?
gychang
Old 6th January 2013, 11:10 AM   #20
Scottmoose's Avatar
Spot on.
To be clear, the damping in the front part should be on the top, back, bottom and one side-wall. A thinner layer of damping should be applied where indicated in green: on the back and one side of the two labyrinth sections, across the top at the bend, and a couple of pieces on the front of each labyrinth section. Since all damping material behaves in a different way, & it also depends on the thickness of the damping material you can get hold of, this will probably need a bit of trial and error, so I suggest one side is left off to allow convenient access to the interior. Blu-Tak or similar makes a good temporary airtight seal & will avoid the need for screws. Straightforward acoustic wadding should do for the job nicely.
I should stress, this box is not a bass monster (these things are relative of course -we're talking about 3in wideband drivers) -I wasn't aiming for maximum extension, but to provide something closer to a TL in terms of the load presented. If used near a front wall, you should get a reasonably balanced response down to about 80Hz since it does provide some modest broadband gain.
TB W3-881SI, which cabinet?Hide this!Advertise here!
"nanoTower" - Tang Band W3-881SI cogitech Full Range 142 8th September 2014 11:20 PM
W3-881SI tabaq kenrhodes Full Range 13 29th September 2013 12:31 AM
Tang Band W3-881SI Line Array Help kctess5 Full Range 16 8th December 2011 11:25 PM
Help with TB w3-1053sc 2500hd Full Range 4 29th May 2010 04:12 PM
Tb W3-593sf sdclc126 Multi-Way 4 19th September 2007 04:14 PM
