The WIBAQ: TABAQ Design with Betsy K - Page 5 - diyAudio
Old 9th January 2013, 09:38 PM   #41
larryldspkr's Avatar
My BetsyK measured at .3218 mh vc inductance!
Larry
Old 9th January 2013, 09:40 PM   #42
The Zobel will roll off the top end! Use the BSC without it.
Larry
Old 9th January 2013, 09:40 PM   #43
Maybe a zobel network is not needed because the baffle width is only 12.5 inches. (Still absorbing as much information as possible, really a noob at this right now)
If this is the case, then we should only need a simple resistor and inductor for the BSC.
Rparallel = Re x (10^db/20 -1)
Rparallel = 5.7 x (10^3/20 -1)
Rparallel = 5.7 x (10^0.15 -1)
Rparallel = 5.7 x 0.413
Rparallel = 2.3541
Rparallel = 2.5 Ohms (Parts-Express)
f3 = 4560/Wb
f3 = 4560/12.5"
f3 = 364.8 Hz
Lbsc = Rparallel/(2 * Pi * f3)
Lbsc = 2.3541/(2 * Pi * 364.8)
Lbsc = 2.3541/2292.106
Lbsc = 1.0 mH
Lbsc = 1.0 mH (Parts-Express)
Last edited by RonVinyl; 9th January 2013 at 09:42 PM. Reason: Added Link Destination
Old 9th January 2013, 09:41 PM   #44
Larry
Thank you Larry for the advice! We greatly appreciate it!
Old 9th January 2013, 09:48 PM   #45
The fewer the components the better. Less cost.
So the BSC you designed, Ron, is a 3db attenuation? That's probably all that's needed with the front port.
Old 9th January 2013, 09:53 PM   #46
Correct, 3 dB attenuation. That is just a starting point. I am going to get a few resistors to try since this is my first BSC.
Old 9th January 2013, 09:58 PM   #47
FYI
Rparallel @1dB 0.696
Rparallel @2dB 1.476
Rparallel @3dB 2.351
Rparallel @4dB 3.334
Rparallel @5dB 4.436
Rparallel @6dB 5.673
Lbsc @1dB 0.3
Lbsc @2dB 0.6
Lbsc @3dB 1.0
Lbsc @4dB 1.5
Lbsc @5dB 1.9
Lbsc @6dB 2.5
Old 9th January 2013, 09:59 PM   #48
Or make the BSC easily adjustable so it can be tuned/adjusted for different environments and preferences. Use some sort of jumper or rotary selector to choose different resistor values for different attenuation
Old 9th January 2013, 10:33 PM   #49
xrk971 is online now xrk971  United States
xrk971's Avatar
Or save your amplifier power and eq it out. Or do the bsc at line level before amp and use much smaller/cheaper inductors and non power resistors. Bsc's burn off power and add phase altering stuff to an otherwise pure full range driver and amp.
Old 9th January 2013, 10:40 PM   #50
My integrated amp does have a 5 band eq, one of which is about 500 hz, which would be convenient for this application. I do like the idea of having the zobel be at line level before the amp, though I listen to mostly vinyl using the amps built in preamp. I don't know how effective feeding a phono signal through a BSC would be.
Folded TABAQ BoomieMCT Full Range 4 26th February 2017 07:17 PM
W3-881SI tabaq kenrhodes Full Range 13 28th September 2013 11:31 PM
TABAQ bookshelf enclosure design yljhao Full Range 34 24th December 2010 11:51 AM
Tall Corner TABAQ Equilibrium Full Range 2 11th April 2010 10:46 PM
Tabaq to the future. raypalmer Multi-Way 7 6th April 2009 03:59 AM
Copyright 1999-2017 diyAudio
