Old 8th January 2013, 10:47 PM   #21
Thanks for the cutting dimensions. When I get home I will go onto sketchup and verify the dimensions. I'm away from home now. I also have a wood shop at my disposal (with a cnc machine) incase Home Depot/lowes gives me trouble. I also know people at home depot, so I could always make sure they are there when I go.
Old 9th January 2013, 12:22 AM   #22
glt is offline glt  United States
Originally Posted by RonVinyl View Post
His dimensions were all internal dimensions since the plywood size is nominal. I will be using 3/4". Here are the dimensions for each piece that I came up with. Do they match up with your cuts glt?
Front: 11" x 43 3/8"
Back: 11" x 46 1/2"
Side: 17 3/4" x 46 1/2"
Top: 11" x 16 1/4"
Bottom: 11" x 17"
Baffle: 11" x 3 1/4"
Front is 44 1/8 as drawn because it is flush with the sides? (don't know why I wrote 15 3/8 :-))
www.hifiduino.wordpress.com
Old 9th January 2013, 01:35 AM   #23
The side panels (x2) are each 17 3/4" by 46 1/2". The front is 11" by 44 1/8". The back is 11" by 46 1/2". The top is 11" by 16 1/4". The bottom is 11" by 17". The port piece is 11" by 3 1/4". So Ron, your dimensions were correct minus the front baffle.
Old 9th January 2013, 11:10 AM   #24
Thanks for the correction, I have updated my design/documents on my end.
Old 9th January 2013, 11:52 AM   #25
Do we have the following information on the Betsy-K:
Impedance of the voice coil (Lvc)
Width of the baffle in inches (Wb)
Old 9th January 2013, 01:03 PM   #26
tubo is offline tubo  Philippines
What kind of stuffing are you guys planning to use and how much?
Old 9th January 2013, 01:03 PM   #27
Stuffing materials i mean
Old 9th January 2013, 01:56 PM   #28
You need 1lb per cubic foot of damping material in this enclosure.
You need to put damping in the top 2/3's of the enclosure.
Here is an option: Acousta-Stuf Polyfill 1 lb. Bag 260-317
11x16.25x45 = 8043.75 cubic inches
8043.75/1728 = 4.654947917 cubic feet
4.654947917 = 1.551649306 in thirds
1.551649306*2 = 3.103298612
So you need roughly 3lbs of damping material.
Old 9th January 2013, 02:16 PM   #29
Thanks ronvinyl
Old 9th January 2013, 02:39 PM   #30
On the PDF of the design the stuffing is listed. About 1.8 pounds in the upper two thirds of each enclosure.
As for the lvc, that I don't know.
W3-881SI tabaq kenrhodes Full Range 3 7th March 2012 11:14 PM
TABAQ bookshelf enclosure design yljhao Full Range 34 24th December 2010 11:51 AM
Tall Corner TABAQ Equilibrium Full Range 2 11th April 2010 10:46 PM
Tabaq to the future. raypalmer Multi-Way 7 6th April 2009 03:59 AM
Folded TABAQ BoomieMCT Full Range 3 7th July 2007 10:08 AM
Copyright ©1999-2013 diyAudio
