The WIBAQ: TABAQ Design with Betsy K
Old 9th January 2013, 03:35 PM   #31
RonVinyl is offline RonVinyl  United States
Originally Posted by Dumbledog View Post
On the PDF of the design the stuffing is listed. About 1.8 pounds in the upper two thirds of each enclosure.
As for the lvc, that I don't know.
I was referring to the TABAQ TL enclosure to get the 1 lb stuffing numbers.
The damping is high (1 lb per ft3) and is placed in the upper part of the pipe. The last third of the pipe is not stuffed. The stuffing will attenuate the output from the opening, so I solved this by increasing the volume of the cabinet.
Wrong source, sorry.
Old 9th January 2013, 08:40 PM   #32
Bjohannesen is offline Bjohannesen  Denmark
Hi
lvc is not known for Betsy K. I have asked the manufacturer but did not get any answer.
Hi from
Bjorn
Old 9th January 2013, 08:40 PM   #33
Originally Posted by Bjohannesen View Post
Hi
Hi from
Bjorn
So Le is not the same as Lvc...
Is there a way to infer what Lvc is?
Old 9th January 2013, 08:42 PM   #34
I suppose if someone had a Betsy-K and a LCR meter we could figure it out right?
Old 9th January 2013, 08:51 PM   #35
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Paul posted this on another site:
Re 6.6 Ohm,
Fs 68.5 Hz,
Sd 211.2,
Md 10.5g
Bl 5.08,
Qms, 4.80,
Qes .770,
Qts .664,
Spl 95db
Vas 48.744L, Mms 7.02g
planet10 needs your help:
Let's help Ruth and Dave
Old 9th January 2013, 09:01 PM   #36
Dumbledog is offline Dumbledog  United States
I have tried to find the Lvc for the Betsy k the past, but I have not had any luck. Are you planning on building a zobel network Ron?
Old 9th January 2013, 09:04 PM   #37
I was looking into it, keeping my options open for now...
What are you planning for your build Dumbledog?
Old 9th January 2013, 09:05 PM   #38
BETSY-K
Re 5.7 ohms
Fs 49.959Hz
Sd 22.966
BL 5.471
Qms 2.798
Qes .548
Qts .458
Spl 94.6
Vas 82.914L
Mms 9.167g
Source: http://www.wildburroaudio.com/speakers.php
Old 9th January 2013, 09:16 PM   #39
Speakerholic
Cal Weldon's Avatar
Ron's specs seem better. I think the ones I quoted were a one off he had made called the Purple Speaker.
Old 9th January 2013, 09:33 PM   #40
I was thinking of forgoing the zobel, since I can't really calculate the design without knowing the Lvc. I was planning on possibly including a baffle step correction circuit if needed, though with the front-firing ported design of the WIBAQ I'm hoping that will enforce the bass enough the baffle step correction won't be needed.
The WIBAQ: TABAQ Design with Betsy KHide this!Advertise here!
Folded TABAQ BoomieMCT Full Range 4 26th February 2017 07:17 PM
W3-881SI tabaq kenrhodes Full Range 13 28th September 2013 11:31 PM
TABAQ bookshelf enclosure design yljhao Full Range 34 24th December 2010 11:51 AM
Tall Corner TABAQ Equilibrium Full Range 2 11th April 2010 10:46 PM
Tabaq to the future. raypalmer Multi-Way 7 6th April 2009 03:59 AM
