The WIBAQ: TABAQ Design with Betsy K
I have luck running a sub with the full range driver instead of boosting the schmoo out of the driver or even crossing the driver over at 100hz even. I'm not keen on the maybe 12-18db filter @80hz to the sub. If I couldn't hear a slot resonance, I'd prefer the 6db f-mod @80hz. But, overall it works great for low to medium volume, especially watching Babylon 5.
I'd flatten that 1-4khz with the filter mentioned by larrldspkr in post #131.
"try a 3k notch filter. 10uf cap .3mh coil and 6-10 ohm resistor, all in parallel and in series with the driver. This worked well for me, and I didn't use BSC filter just the notch."
http://www.diyaudio.com/forums/full-range/226767-wibaq-tabaq-design-betsy-k-14.html
