Aura Sound NS3 Test Results
Old 31st December 2012, 05:13 PM   #1
bikinpunk is offline bikinpunk  United States
Default Aura Sound NS3 Test Results
Some of you guys may have already seen this on tech-talk but for those who haven't and may be interested in the results, here you go...
Aura Sound NS3-193-8A1 | Medley's Musings
For $12, I'm not sure this can be beat. Though, the really low sensitivity may be a serious issue to some.
Highlights:
  • 3.5mm linear xmax (bl limited)
  • nearly ruler flat response from 200-5khz. notch out the peak at 6.5khz and you're flat to 10khz
Old 31st December 2012, 06:30 PM   #2
R.I.P.
Ideally used as a 1.5 way , or in a 2.5 way or 2 way MTM to address the
limited sensitivity and bump up the maximum SPL, with small tweeter, clearly
still optimised for AV type bass extension as you'd expect from small drivers.
Some interesting comments on Zaphs site about these drivers.
http://zaphaudio.com/archives.html
rgds, sreten.
Old 31st December 2012, 06:44 PM   #3
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
To bad that peak at 6500 hz is such high q. Would be hard to filter out if running full range.
Thanks for the testing!
Old 31st December 2012, 06:55 PM   #4
Interesting that Zaph suggests glueing the speaker. I actually used screws but put a bead of silicone around the edge because I was worried about the things he noted.
Old 1st January 2013, 10:22 AM   #5
wesayso is offline wesayso  Netherlands
wesayso's Avatar
The Vifa TC9FD18-08 3.5" might beat it....
Look it up at Zaph: Zaph|Audio
The Madisound Speaker Store $ 11,75
I do realise you play it a bit louder than him for the distortion test though... It would be fun to know.
Old 1st January 2013, 11:46 AM   #6
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
The Vifa is one of my favorites and truly, it is tough to beat for the price, and I was thinking the same thing... To be fair, the NS3 has a lower fs and a huge excursion in comparison. Some folks like to see their drivers turn inside out on a kick drum
Aura Sound NS3 Test ResultsHide this!Advertise here!
Aura NS3-193-8A castlesteve Full Range 15 25th October 2011 03:04 PM
FS: Aura NS3-193s (Black) mazeroth Swap Meet 2 5th March 2008 01:48 AM
Another Aura NS3 PC Speaker Timn8ter Full Range 18 24th January 2008 08:10 PM
Need advice for 1st project (Aura NS3) squib Full Range 47 6th November 2007 02:07 PM
Any Aura NS3 plans like the Cyburgs-Needles? mazeroth Full Range 2 19th May 2006 01:40 AM
